azimir wrote on Thursday, May 22, 2008:
I am attempting to build the ATmega323 port in WinAVR (gcc version 4.3.0 (WinAVR 20080512)) from the 4.8.0 release of FreeRTOS.
I have applied the fix listed from the forum to fix the signed-ness interface definitions:
https://sourceforge.net/forum/message.php?msg_id=4877178
After I rebuild I get this output (and the same kinds of errors for a number of files):
Compiling: main.c
avr-gcc -c -mmcu=atmega323 -I. -D GCC_MEGA_AVR -I. -I…/…/Source/include -I…/Common/include -g -Os -fsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wextra -Wshadow -Wpointer-arith -Wbad-function-cast -Wcast-align -Wsign-compare -Waggregate-return -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wunused -Wa,-adhlns=main.lst -std=gnu99 main.c -o main.o
main.c: In function ‘main’:
main.c:193: warning: pointer targets in passing argument 2 of ‘xTaskCreate’ differ in signedness
main.c: At top level:
…/…/Source/include/task.h:973: warning: inline function ‘vTaskSwitchContext’ declared but never defined
…/…/Source/include/task.h:910: warning: inline function ‘vTaskIncrementTick’ declared but never defined
Having searched through a good portion of the sources and ports, it looks like vTaskSwitchContext and vTaskIncrementTick are to be implemented by the port, but I’m having trouble tracking down where it should be.
Has anyone seen this before?
Thank you for your time.
