- I have VisualStudio, project compiles, but when I run application I get following error message on output
The following network interfaces are available:
Interface 1 - rpcap://{1A54E5A1-C92F-4CC9-AE85-08EF97D0F0EC}
(Network adapter ‘Microsoft’ on local host)
Interface 2 - rpcap://{2E6C36FF-5F94-47F2-868A-E96BCA39C798}
(Network adapter ‘VMware Virtual Ethernet Adapter’ on local host)
Interface 3 - rpcap://{C2DCD81A-6428-41C1-85A6-C3D15CC1CB3A}
Interface 4 - rpcap://{4CC1AF80-AFB2-4061-88C1-09760DCFBB55}
Interface 5 - rpcap://{F925CFEA-87A9-4D1A-8990-DF38EE2040FF}
(Network adapter ‘TAP-Windows Adapter V9’ on local host)
Interface 6 - rpcap://{2187BA45-2A2D-4A15-B744-F3D56FB71696}
Interface 7 - rpcap://{FB907469-1757-4BDD-9EC2-5FE0FF3E40EA}
The interface that will be opened is set by “configNETWORK_INTERFACE_TO_USE”, which
should be defined in FreeRTOSConfig.h
Attempting to open interface number 4.
Successfully opened interface number 4.
FATAL Bad Memory Block.
- my goal is to run it with Eclipse and MinGW
I solved problem with “could not be resolved” by modifying order of includes in project!
only problem remains
expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘attribute’ before ‘__mingw__snprintf’
expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘attribute’ before ‘__mingw__vsnprintf’
complete console output (sorry as new user I cannot upload files)
19:22:20 **** Rebuild of configuration Debug for project Rcom ****
Info: Internal Builder is used for build
gcc -DprojCOVERAGE_TEST=0 “-ID:\Users\Ra\Documents\EWorkspace2\Rcom” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source\portable\MemMang” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source\portable\MSVC-MingW” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\Trace_Recorder_Configuration” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-Trace” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-Trace\Include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-Trace\streamports\File” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-Trace\streamports\File\include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\portable\Compiler\GCC” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\portable\BufferManagement” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\Utilities\logging” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\WinPCap” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\DemoTasks\include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source\include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source\portable” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source” -O0 -g3 -Wall -c -fmessage-length=0 -o “DemoTasks\TCPEchoClient_SingleTasks.o” “…\DemoTasks\TCPEchoClient_SingleTasks.c”
gcc -DprojCOVERAGE_TEST=0 “-ID:\Users\Ra\Documents\EWorkspace2\Rcom” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source\portable\MemMang” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source\portable\MSVC-MingW” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\Trace_Recorder_Configuration” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-Trace” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-Trace\Include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-Trace\streamports\File” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-Trace\streamports\File\include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\portable\Compiler\GCC” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\portable\BufferManagement” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\Utilities\logging” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\WinPCap” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\DemoTasks\include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source\include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source\portable” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source” -O0 -g3 -Wall -c -fmessage-length=0 -o “FreeRTOS\Source\portable\MemMang\heap_5.o” “…\FreeRTOS\Source\portable\MemMang\heap_5.c”
gcc -DprojCOVERAGE_TEST=0 “-ID:\Users\Ra\Documents\EWorkspace2\Rcom” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source\portable\MemMang” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source\portable\MSVC-MingW” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\Trace_Recorder_Configuration” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-Trace” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-Trace\Include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-Trace\streamports\File” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-Trace\streamports\File\include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\portable\Compiler\GCC” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\portable\BufferManagement” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\Utilities\logging” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\WinPCap” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\DemoTasks\include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source\include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source\portable” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source” -O0 -g3 -Wall -c -fmessage-length=0 -o “FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\FreeRTOS_IP.o” “…\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\FreeRTOS_IP.c”
…\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\FreeRTOS_IP.c: In function ‘prvAllowIPPacket’:
…\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\FreeRTOS_IP.c:1919:66: warning: taking address of packed member of ‘struct xUDP_HEADER’ may result in an unaligned pointer value [-Waddress-of-packed-member]
1919 | pusChecksum = ( const uint16_t * ) ( &( pxProtPack->xUDPPacket.xUDPHeader.usChecksum ) );
…\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\FreeRTOS_IP.c: In function ‘usGenerateProtocolChecksum’:
…\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\FreeRTOS_IP.c:2517:44: warning: taking address of packed member of ‘struct xUDP_HEADER’ may result in an unaligned pointer value [-Waddress-of-packed-member]
2517 | pusChecksum = ( uint16_t * ) ( &( pxProtPack->xUDPPacket.xUDPHeader.usChecksum ) );
…\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\FreeRTOS_IP.c:2533:44: warning: taking address of packed member of ‘struct xTCP_HEADER’ may result in an unaligned pointer value [-Waddress-of-packed-member]
2533 | pusChecksum = ( uint16_t * ) ( &( pxProtPack->xTCPPacket.xTCPHeader.usChecksum ) );
…\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\FreeRTOS_IP.c:2550:44: warning: taking address of packed member of ‘struct xICMP_HEADER’ may result in an unaligned pointer value [-Waddress-of-packed-member]
2550 | pusChecksum = ( uint16_t * ) ( &( pxProtPack->xICMPPacket.xICMPHeader.usChecksum ) );
gcc -DprojCOVERAGE_TEST=0 “-ID:\Users\Ra\Documents\EWorkspace2\Rcom” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source\portable\MemMang” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source\portable\MSVC-MingW” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\Trace_Recorder_Configuration” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-Trace” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-Trace\Include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-Trace\streamports\File” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-Trace\streamports\File\include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\portable\Compiler\GCC” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\portable\BufferManagement” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\Utilities\logging” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\WinPCap” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\DemoTasks\include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source\include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source\portable” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source” -O0 -g3 -Wall -c -fmessage-length=0 -o “FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\FreeRTOS_TCP_WIN.o” “…\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\FreeRTOS_TCP_WIN.c”
gcc -DprojCOVERAGE_TEST=0 “-ID:\Users\Ra\Documents\EWorkspace2\Rcom” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source\portable\MemMang” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source\portable\MSVC-MingW” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\Trace_Recorder_Configuration” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-Trace” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-Trace\Include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-Trace\streamports\File” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-Trace\streamports\File\include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\portable\Compiler\GCC” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\portable\BufferManagement” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\Utilities\logging” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\WinPCap” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\DemoTasks\include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source\include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source\portable” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source” -O0 -g3 -Wall -c -fmessage-length=0 -o “FreeRTOS\Source\tasks.o” “…\FreeRTOS\Source\tasks.c”
gcc -DprojCOVERAGE_TEST=0 “-ID:\Users\Ra\Documents\EWorkspace2\Rcom” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source\portable\MemMang” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source\portable\MSVC-MingW” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\Trace_Recorder_Configuration” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-Trace” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-Trace\Include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-Trace\streamports\File” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-Trace\streamports\File\include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\portable\Compiler\GCC” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\portable\BufferManagement” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\Utilities\logging” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\WinPCap” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\DemoTasks\include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source\include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source\portable” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source” -O0 -g3 -Wall -c -fmessage-length=0 -o “FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\FreeRTOS_ARP.o” “…\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\FreeRTOS_ARP.c”
gcc -DprojCOVERAGE_TEST=0 “-ID:\Users\Ra\Documents\EWorkspace2\Rcom” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source\portable\MemMang” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source\portable\MSVC-MingW” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\Trace_Recorder_Configuration” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-Trace” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-Trace\Include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-Trace\streamports\File” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-Trace\streamports\File\include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\portable\Compiler\GCC” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\portable\BufferManagement” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\Utilities\logging” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\WinPCap” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\DemoTasks\include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source\include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source\portable” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source” -O0 -g3 -Wall -c -fmessage-length=0 -o “FreeRTOS\Source\portable\MSVC-MingW\port.o” “…\FreeRTOS\Source\portable\MSVC-MingW\port.c”
gcc -DprojCOVERAGE_TEST=0 “-ID:\Users\Ra\Documents\EWorkspace2\Rcom” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source\portable\MemMang” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source\portable\MSVC-MingW” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\Trace_Recorder_Configuration” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-Trace” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-Trace\Include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-Trace\streamports\File” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-Trace\streamports\File\include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\portable\Compiler\GCC” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\portable\BufferManagement” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\Utilities\logging” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\WinPCap” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\DemoTasks\include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source\include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source\portable” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source” -O0 -g3 -Wall -c -fmessage-length=0 -o “FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\FreeRTOS_UDP_IP.o” “…\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\FreeRTOS_UDP_IP.c”
gcc -DprojCOVERAGE_TEST=0 “-ID:\Users\Ra\Documents\EWorkspace2\Rcom” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source\portable\MemMang” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source\portable\MSVC-MingW” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\Trace_Recorder_Configuration” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-Trace” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-Trace\Include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-Trace\streamports\File” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-Trace\streamports\File\include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\portable\Compiler\GCC” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\portable\BufferManagement” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\Utilities\logging” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\WinPCap” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\DemoTasks\include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source\include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source\portable” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source” -O0 -g3 -Wall -c -fmessage-length=0 -o “FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\FreeRTOS_Sockets.o” “…\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\FreeRTOS_Sockets.c”
gcc -DprojCOVERAGE_TEST=0 “-ID:\Users\Ra\Documents\EWorkspace2\Rcom” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source\portable\MemMang” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source\portable\MSVC-MingW” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\Trace_Recorder_Configuration” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-Trace” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-Trace\Include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-Trace\streamports\File” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-Trace\streamports\File\include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\portable\Compiler\GCC” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\portable\BufferManagement” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\Utilities\logging” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\WinPCap” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\DemoTasks\include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source\include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source\portable” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source” -O0 -g3 -Wall -c -fmessage-length=0 -o “FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\FreeRTOS_Stream_Buffer.o” “…\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\FreeRTOS_Stream_Buffer.c”
gcc -DprojCOVERAGE_TEST=0 “-ID:\Users\Ra\Documents\EWorkspace2\Rcom” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source\portable\MemMang” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source\portable\MSVC-MingW” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\Trace_Recorder_Configuration” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-Trace” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-Trace\Include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-Trace\streamports\File” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-Trace\streamports\File\include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\portable\Compiler\GCC” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\portable\BufferManagement” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\Utilities\logging” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\WinPCap” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\DemoTasks\include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source\include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source\portable” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source” -O0 -g3 -Wall -c -fmessage-length=0 -o “FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\FreeRTOS_DNS.o” “…\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\FreeRTOS_DNS.c”
gcc -DprojCOVERAGE_TEST=0 “-ID:\Users\Ra\Documents\EWorkspace2\Rcom” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source\portable\MemMang” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source\portable\MSVC-MingW” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\Trace_Recorder_Configuration” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-Trace” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-Trace\Include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-Trace\streamports\File” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-Trace\streamports\File\include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\portable\Compiler\GCC” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\portable\BufferManagement” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\Utilities\logging” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\WinPCap” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\DemoTasks\include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source\include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source\portable” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source” -O0 -g3 -Wall -c -fmessage-length=0 -o main.o “…\main.c”
gcc -DprojCOVERAGE_TEST=0 “-ID:\Users\Ra\Documents\EWorkspace2\Rcom” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source\portable\MemMang” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source\portable\MSVC-MingW” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\Trace_Recorder_Configuration” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-Trace” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-Trace\Include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-Trace\streamports\File” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-Trace\streamports\File\include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\portable\Compiler\GCC” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\portable\BufferManagement” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\Utilities\logging” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\WinPCap” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\DemoTasks\include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source\include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source\portable” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source” -O0 -g3 -Wall -c -fmessage-length=0 -o “FreeRTOS\Source\queue.o” “…\FreeRTOS\Source\queue.c”
gcc -DprojCOVERAGE_TEST=0 “-ID:\Users\Ra\Documents\EWorkspace2\Rcom” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source\portable\MemMang” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source\portable\MSVC-MingW” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\Trace_Recorder_Configuration” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-Trace” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-Trace\Include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-Trace\streamports\File” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-Trace\streamports\File\include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\portable\Compiler\GCC” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\portable\BufferManagement” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\Utilities\logging” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\WinPCap” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\DemoTasks\include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source\include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source\portable” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source” -O0 -g3 -Wall -c -fmessage-length=0 -o “Common\Logging\windows\Logging_WinSim.o” “…\Common\Logging\windows\Logging_WinSim.c”
…\Common\Logging\windows\Logging_WinSim.c: In function ‘prvWin32LoggingThread’:
…\Common\Logging\windows\Logging_WinSim.c:480:1: warning: no return statement in function returning non-void [-Wreturn-type]
480 | }
gcc -DprojCOVERAGE_TEST=0 “-ID:\Users\Ra\Documents\EWorkspace2\Rcom” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source\portable\MemMang” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source\portable\MSVC-MingW” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\Trace_Recorder_Configuration” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-Trace” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-Trace\Include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-Trace\streamports\File” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-Trace\streamports\File\include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\portable\Compiler\GCC” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\portable\BufferManagement” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\Utilities\logging” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\WinPCap” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\DemoTasks\include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source\include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source\portable” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source” -O0 -g3 -Wall -c -fmessage-length=0 -o “DemoTasks\SimpleUDPClientAndServer.o” “…\DemoTasks\SimpleUDPClientAndServer.c”
…\DemoTasks\SimpleUDPClientAndServer.c: In function ‘prvSimpleClientTask’:
…\DemoTasks\SimpleUDPClientAndServer.c:131:84: warning: format ‘%lu’ expects argument of type ‘long unsigned int’, but argument 3 has type ‘uint32_t’ {aka ‘unsigned int’} [-Wformat=]
131 | sprintf( ( char * ) cString, “Server received (not zero copy): Message number %lu\r\n”, ulCount );
| | uint32_t {aka unsigned int}
| long unsigned int
| %u
…\DemoTasks\SimpleUDPClientAndServer.c: In function ‘prvSimpleServerTask’:
…\DemoTasks\SimpleUDPClientAndServer.c:155:9: warning: variable ‘lBytes’ set but not used [-Wunused-but-set-variable]
155 | int32_t lBytes;
…\DemoTasks\SimpleUDPClientAndServer.c: In function ‘prvSimpleZeroCopyUDPClientTask’:
…\DemoTasks\SimpleUDPClientAndServer.c:259:50: warning: format ‘%lu’ expects argument of type ‘long unsigned int’, but argument 4 has type ‘uint32_t’ {aka ‘unsigned int’} [-Wformat=]
259 | sprintf( ( char * ) pucUDPPayloadBuffer, “%s%lu\r\n”, pcStringToSend, ulCount );
| long unsigned int uint32_t {aka unsigned int}
| %u
gcc -DprojCOVERAGE_TEST=0 “-ID:\Users\Ra\Documents\EWorkspace2\Rcom” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source\portable\MemMang” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source\portable\MSVC-MingW” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\Trace_Recorder_Configuration” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-Trace” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-Trace\Include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-Trace\streamports\File” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-Trace\streamports\File\include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\portable\Compiler\GCC” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\portable\BufferManagement” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\Utilities\logging” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\WinPCap” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\DemoTasks\include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source\include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source\portable” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source” -O0 -g3 -Wall -c -fmessage-length=0 -o “FreeRTOS-Plus\Source\FreeRTOS-Plus-Trace\streamports\TCPIP_Win32\trcStreamingPort.o” “…\FreeRTOS-Plus\Source\FreeRTOS-Plus-Trace\streamports\TCPIP_Win32\trcStreamingPort.c”
gcc -DprojCOVERAGE_TEST=0 “-ID:\Users\Ra\Documents\EWorkspace2\Rcom” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source\portable\MemMang” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source\portable\MSVC-MingW” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\Trace_Recorder_Configuration” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-Trace” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-Trace\Include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-Trace\streamports\File” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-Trace\streamports\File\include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\portable\Compiler\GCC” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\portable\BufferManagement” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\Utilities\logging” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\WinPCap” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\DemoTasks\include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source\include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source\portable” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source” -O0 -g3 -Wall -c -fmessage-length=0 -o “FreeRTOS\Source\list.o” “…\FreeRTOS\Source\list.c”
gcc -DprojCOVERAGE_TEST=0 “-ID:\Users\Ra\Documents\EWorkspace2\Rcom” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source\portable\MemMang” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source\portable\MSVC-MingW” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\Trace_Recorder_Configuration” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-Trace” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-Trace\Include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-Trace\streamports\File” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-Trace\streamports\File\include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\portable\Compiler\GCC” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\portable\BufferManagement” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS-Plus\Source\Utilities\logging” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\WinPCap” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\DemoTasks\include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source\include” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source\portable” “-ID:\Users\Ra\Documents\EWorkspace2\Rcom\FreeRTOS\Source” -O0 -g3 -Wall -c -fmessage-length=0 -o “FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\portable\NetworkInterface\WinPCap\NetworkInterface.o” “…\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\portable\NetworkInterface\WinPCap\NetworkInterface.c”
In file included from D:\Users\Ra\Documents\EWorkspace2\Rcom\WinPCap/pcap/pcap.h:54,
from D:\Users\Ra\Documents\EWorkspace2\Rcom\WinPCap/pcap.h:45,
from …\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\portable\NetworkInterface\WinPCap\NetworkInterface.c:28:
C:/TDM-GCC-32/include/stdio.h:345:12: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘attribute’ before ‘__mingw__snprintf’
345 | extern int mingw_stdio_redirect(snprintf)(char*, size_t, const char*, …);
C:/TDM-GCC-32/include/stdio.h:349:12: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘attribute’ before ‘__mingw__vsnprintf’
349 | extern int mingw_stdio_redirect(vsnprintf)(char*, size_t, const char*, __VALIST);
…\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\portable\NetworkInterface\WinPCap\NetworkInterface.c: In function ‘prvPrintAvailableNetworkInterfaces’:
…\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\portable\NetworkInterface\WinPCap\NetworkInterface.c:282:76: warning: format ‘%d’ expects argument of type ‘int’, but argument 2 has type ‘BaseType_t’ {aka ‘long int’} [-Wformat=]
282 | printf( “\r\nERROR: configNETWORK_INTERFACE_TO_USE is set to %d, which is an invalid value.\r\n”, xConfigNetworkInterfaceToUse );
| int BaseType_t {aka long int}
| %ld
…\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\portable\NetworkInterface\WinPCap\NetworkInterface.c:297:59: warning: format ‘%d’ expects argument of type ‘int’, but argument 2 has type ‘BaseType_t’ {aka ‘long int’} [-Wformat=]
297 | printf( “Attempting to open interface number %d.\n”, xConfigNetworkInterfaceToUse );
| %ld
…\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\portable\NetworkInterface\WinPCap\NetworkInterface.c: In function ‘prvWinPcapSendThread’:
…\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\portable\NetworkInterface\WinPCap\NetworkInterface.c:485:17: warning: unused variable ‘cErrorMessage’ [-Wunused-variable]
485 | static char cErrorMessage[ 1024 ];
…\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\portable\NetworkInterface\WinPCap\NetworkInterface.c: In function ‘prvRemoveSpaces’:
…\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\portable\NetworkInterface\WinPCap\NetworkInterface.c:668:13: warning: implicit declaration of function ‘isspace’ [-Wimplicit-function-declaration]
668 | if( isspace( *pcMessage ) != pdFALSE )
At top level:
…\FreeRTOS-Plus\Source\FreeRTOS-Plus-TCP\portable\NetworkInterface\WinPCap\NetworkInterface.c:485:17: warning: ‘cErrorMessage’ defined but not used [-Wunused-variable]
19:22:32 Build Failed. 2 errors, 13 warnings. (took 11s.680ms)
