guitardenver wrote on Thursday, March 08, 2018:
I’m designing a system, and I want to have 3 event groups that many tasks will be watching for.
I want to have a task that triggers on specific events on the event groups and also triggers on a queue as well.
I guess i’m trying to make a single task be event driven with multiple RTOS types. What is the best way to do this? Is this a common thing to do or is there a better way to do event driven tasks?
I can only think of a few options:
- Use one task that blocks for a short time on each and “polls” until one triggers
- Create a task for each event group and queue and then have those tasks send the event or queue to a another common task through a queue.
- Get rid of the event groups entirly and send the events and queue messages through a global queue that only one task writes to and all other tasks only read from. (This seems to be the best option)
To syncronize when the event and/or global queue message is cleared, all tasks that block on an event group or global queue, will need to register with the single event producer, and every task will send a directTask notification to the producer letting it know it completed its task for the event. Once the task notification counter is the value of tasks registered to that event, it will clear the event flag.
The goal of the design:
Say there are 4 modules that control 4 different things (say LED, solinoid, display, motor). When an event happens, each module needs to execute a task.
One way to do this is to have one task listen to all events and then tell each module what to do for that event. Ex: Event A = Turn off LED, latch solinoid, display “Help”, turn off motor".
The way I was thinking about doing it is that each module is responsible for what needs to be done.
Ex: Event A
- LED module will un-block and turn off the LED
- solinoid module with un-block and latch the solinoid
- display module will un-block and display “Help”
-motor module will un-block and turn off the motor
This way the functionality of the module stay isolated to the module itself. They can be written independently and a central task does not have to call functions in each module to handle an event. This makes for far more moduler code that is very easy to integrate with the rest of the modules. I hope i’m explaining this well enough.
Any ideas on how to acheive this modularity with FreeRTOS?
