I’m working on a project where I have to write to an SD card from more than one task. For this I use mutex.
I use SPI to communicate with the SD card, plus I have to use an EEPROM that share the same SPI bus witht he SD card. First idea that came in my mind is to use one mutex to share the SPI bus between SD card and EEPROM and also between different tasks that write/read from the SD card.
Is there a better efficient way to manage my case ?
The minor nit is that it seems you are making public an implementation detail (the SD card and the EEPROM are on the same bus), but the actual mutex access can be put into the device driver APIs.
There could be some argument for having a second mutex outside the SPI bus mutex for just the SD card (or just the EEPROM) if the application layer needs to do multiple transactions that need to stay “atomic” (like reading a sector to update it). With just a single mutex, the task would need to lock out the EEPROM too during the update cycle.
