Hello, im beggining with FreeRTOS, and i want to put data in a port, lets say blink a led, i cant understand how to set port data with a task, i would like some examples i tried to understand the demos but i couldnt, can you help me? how to blink a led?
the second question is, if i set the configuration bits with a tx x8pll should i delete something in the freeRTOS source files? cause i set the config bits in the mplab ide.
please explain like im a total begginer because i am. thanks everyone who can help
toggle_led() is the function you write to write to the port.
As I remember you can set bits in the source code or in the MPLAB project, but not both. If the project defines the bits in the source code and you want to set them in the project then I guess you will have to delete something. Read the documentation for MPLAB.
FreeRTOS does not set anything for the cpu clock? i mean if i don’t do it, the FreeRTOS source code does not set anything that has to do with config bits?
I was asking about the toggle_led function in your example, how do i set a bit in a port? using Assembler? should i create a *.h file?
FreeRTOS does not do anything to “setup” your basic processor, except for those things that it exclusively uses. It will configure the tick timer and related interrupt.
You need to configure the rest of the processor in the manner that you need.
If you are not familiar with the processor, I would suggest that you look at the basic Microchip provided examples to understand how the processor works, and how to write code for it.
Prior to starting with an RTOS, you should understand the basics of the
processor your using…
Read the data sheet for the part, understand how I/O works and start
learning about all of the peripheral devices on the part…
Then its time to explore RTOS…
here is a good place to start…
Two great books on the PIC24/dsPIC:
Microcontrollers: From Assembly Language to C Using the PIC24 Family <—
great book, New edition do any time now
related interrupt.
need.
