i’m a newbie to the RTOS and to this group, previously i was working with BF561. I have downloaded the freertos v4.6.1 and tried the demo for STR91X in IAR KS v4.0, but in the 91x_vect-IAR.s file am getting a compiler error like
Bad instruction in the line - COMMON INTVEC:CODE(2)
>Fatal Error[e89]: Too much object code produced (more than 0x8000 bytes) for this package
From this error message I’m guessing you are using the KickStart version of the IAR compiler - which is limited to 32K. You are simply going over this limit.
The STR9 project contains several configurations, one of which was deliberately kept below the 32K code size limit so it can be used with the KickStart version. I think the documentation page for this port tells you which project this is.
I have converted all the IAR projects for use with Embedded Workbench version 5 now, but these are not yet in the .zip file download.
thank you Richard.
I’m having Embedded work bench 5.11 also but the project is in the version 4.0 Kickstart.
I have read the documentation for upgrading the FreeRTOS projects from 4.x to 5.x IAR, in that documentation they have specified about the Cstartup.s file in the FreeRTOS download but in the download there is no such file instead i have 91x_init_IAR.s and 91x_vect_IAR.s files.
I’m using the STR91X demo. I tried taking these two .s files and included a Cstartup.s from the IAR examples but not from the example of STR but from the STR library as the STR doesn’t contain any .s.
I compiled the project but ends with the following error.
1)
Warning[Lp005]: placement includes a mix of sections with content (example "rw data section .data in httpd-cgi.o") and sections without content (example "zi section .bss
in 91x_enet.o")
2)
Warning[Lp006]: placement includes a mix of writable sections (example "zi section .bss in 91x_enet.o") and non-writable sections (example "ro data section .rodata in
BlockQ.o")
Help me to make through the project either by the Kickstart or EWARM 5.11.
If you send me your real email address as apposed to the SourceForge address then I can send you the V5.11 version. SourceForge email addresses will not allow binary attachments.
