In queue.c from FreeRTOS 8.2.2 the xQueueGenericCreate function ends (see line 383 on) with:
configASSERT( xReturn );
return xReturn;
so it’s impossible for the function to return NULL without triggering the assertion. However the documentation (http://www.freertos.org/a00116.html) states that xQueueCreate can return 0 to indicate failure.
If assertions were turned off this function would operate as documented, so it seems like this assert should not be present.
Look at the definitions of xQueueGenericCreate() and
xQueueGenericCreateStatic() in the head revision (lines 384 and 332 at
the time of posting) - the assert was removed, but after rc1. Since rc1
some simplification of the static allocation code has been made.
