When using a 2g/3g/4g module, with TLS manage by the application using for example mbetls, the reading of the data is often done by polling. Based ton the media that can be slow, the RX timeout has to be quite large enough to consider bad network condition. That said, when the core-mqtt want to check if data is received, it launch a read operation on the socket. This read on the physical module is oftenly just a simple check about received bytes. However, as the timeout is quite big, this operation takes a lot amount of time which is useless. For this specific operation of polling for received data, the timeout should be shorten I think. Otherwise, any pending publish should wait for the socket to be released.
I hope the explanation is complete enough to be understandable.
[159.276] >> TLS_FreeRTOS_recv bytesToRecv:1 ← this is the latest polling request from core-mqtt
[159.277] >> Modem_Recv 5 bytes <<
[159.305] Modem TX → AT#SI=1
[159.329] RX ← “#SI: 1,1788,5694,0,0”
[159.339] RX ← “OK”
[159.457] >> Modem_Recv 5 bytes <<
[159.482] Modem TX → AT#SI=1
[159.494] RX ← “#SI: 1,1788,5694,0,0”
[159.507] RX ← “OK”
[159.631] >> Modem_Recv 5 bytes <<
[159.652] Modem TX → AT#SI=1
[159.670] RX ← “#SI: 1,1788,5694,0,0”
[159.680] RX ← “OK”
[159.799] >> Modem_Recv 5 bytes <<
[159.824] Modem TX → AT#SI=1
[159.836] RX ← “#SI: 1,1788,5694,0,0”
[159.846] RX ← “OK”
[159.904] Sending publish request to agent with message on topic “…” ← this is the MQTT_Publish
[159.923] Task waiting for publish 3 to complete.
[159.968] >> Modem_Recv 5 bytes <<
[159.986] Modem TX → AT#SI=1
[159.997] RX ← “#SI: 1,1788,5694,0,0”
[160.007] RX ← “OK”
[160.119] >> Modem_Recv 5 bytes <<
[160.137] Modem TX → AT#SI=1
[160.148] RX ← “#SI: 1,1788,5694,0,0”
[160.160] RX ← “OK”
[160.270] >> Modem_Recv 5 bytes <<
[160.281] Modem TX → AT#SI=1
[160.296] RX ← “#SI: 1,1788,5694,0,0”
[160.306] RX ← “OK”
[160.423] >> Modem_Recv 5 bytes <<
[160.440] Modem TX → AT#SI=1
[160.452] RX ← “#SI: 1,1788,5694,0,0”
[160.464] RX ← “OK”
[160.575] >> Modem_Recv 5 bytes <<
[160.594] Modem TX → AT#SI=1
[160.606] RX ← “#SI: 1,1788,5694,0,0”
[160.619] RX ← “OK”
[160.735] >> Modem_Recv 5 bytes <<
[160.748] Modem TX → AT#SI=1
[160.760] RX ← “#SI: 1,1788,5694,0,0”
[160.770] RX ← “OK”
[160.905] >> Modem_Recv 5 bytes <<
[160.923] Modem TX → AT#SI=1
[160.940] RX ← “#SI: 1,1788,5694,0,0”
[160.956] RX ← “OK”
[161.066] >> TLS_FreeRTOS_send bytesToSend:32 ← this is the request to send data packet
[161.077] Modem_Send: request
[161.347] Successfully sent 61 bytes over network.
[161.348] Sockets_Send out
[161.349] >> TLS_FreeRTOS_send bytesToSend:9
[161.350] Sockets_Send in
[161.350] Modem_Send: request
[161.361] Modem TX → AT#SSENDEXT=1,38
[161.375] RX ← “>”
[161.376] Modem TX →
[161.392] RX ← “OK”
