Hi all,
I use AWS IoT Device Tester to qualify my device according to Amazon.
Sometimes I failed at FreeRTOSIntegrity with the error:
“Following files are modified…”
I wonder that which files are used to compare with my source code in this test?
Hi all,
Each FreeRTOS release contains a checksums.json
file which has checksums for source files that a new port/qualification is not expected to modify: https://github.com/aws/amazon-freertos/blob/202007.00/checksums.json
The integrity checks calculates the checkesums for local files and validates against the values in checksums.json
Thanks for your useful information!
May I know which type of checksums are used for FreeRTOS (MD5/SHA…)? And can we specify that type for IDT?
My question came from the issue that I do not modify any files in that checksum list but the hash does not match.
Thanks!
