Dear all,
I am still playing with the new OTA library and noticed a job-document syntax discrepancy between jobs created via the boto3 create_ota_update and the usual FreeRTOS-ARF-Job creation user interface from the console.
I noticed that from the console, the file array contains the key sig-sha256-ecdsa while when created from the boto3 library, the key name is sig-sha-256-ecdsa, which is not compatible with the new OTA library (parse failure).
Is that only me ? Or does it depend on the platform ID I use ? Or something else?
Thank’s in advance. Lucas
PS: by the way, could it be possible to add the FileVersion’s in the Job Document ? It would be really helpful ![]()
