meerkoetter wrote on Wednesday, April 24, 2019:
I used a V7.x version of FreeRtos so far. Last week I tried to switch my project to V10.2.0. It compiled, but worked in a strange way. After some debugging I found that the function prvScheduleNextTick in port.c is broken. This function is used, if the tick irq is generated by the CPU internal count register (Option configTICK_USE_TC==0).
In the V7.x version the code was correct, but now it assumes that the system register COUNT is free running and can be used to detect missed ticks. That’s not possible, the register is cleared to 0 at each compare match.
This wrong assumption will lead to a completely wrong tick frequenzy.
