I am relatively new to the free RTOS but have been developing some new code using it and things have been progressing pretty well. That is until I have reached a certain code size on my device > 78500. Now when I try to delete the first startup task my code resets. I realize there is no official port but wonder if there are some pointers as to what is going wrong.
Heap and stack are ok plenty of space there.
I have enabled task delete and suspend. (using either from within the task cause a re start)
Where did you get the code from? The official ATMega port does not support the larger memory devices. Supporting the larger memory devices is, I believe, quite straight forward and requires that a couple of extra RAMn registers are saved in the task context. Is your port doing that?
Just from a brief look, without referring to the manuals, I think you need to also be storing RAMX and RAMY (or something like that) in addition to the registers in your post if you want to go above 64K. You would also need to have initial values for the extra registers in the stack setup for a task when the task is created.
