m2b821 wrote on Monday, October 30, 2017:
Hello, I have a problem with my code. I run a several tasks on FreeRTOS (v7.3, supplied from Atmel ASF) and added a set of new tasks for ADC conversion. I tested the ADC part before without FreeRTOS and it worked fine. But after calling NVIC_EnableIRQ(ADC_IRQn);, FreeRTOS scheduling ends (no task is called again) while the ADC interrupts remain. I have the standard configuration from Atmel, which is using 4 bits for the priorities. I tried to call also moving the call to NVIC_EnableIRQ(ADC_IRQn); before creating any tasks, but this resulted in the same behaviour. Can someone please explain me why, as I am pretty sure that NVIC_EnableIRQ causes the crash, this stops the FreeRTOS kernel. I have already read http://www.freertos.org/RTOS-Cortex-M3-M4.html and used configASSERT on all semaphores and tasks related to this issue.
The ADC interrupts simply loads the result of from two ADC channels and stores them in a local variable. Afterwards it calls the corresponding task through releasing a binary semaphore. The ADC is operating hardware controlled using timer 0 with 10Hz. I understand FreeRTOS this way, the timer 0 and 1 are not consumed by it (it uses sysclk, correct?). As I have other components which will be integrated in my main application with FreeRTOS, I fear that similar errors might occur, as I2C and USB CDC also use hardware interrupts with NVIC_EnableIRQ(...).
The semaphore is all 10Hz released, but no task is ever called after startup (where the ADC task is once called):
long prio = pdFALSE;
xSemaphoreGiveFromISR(*(getSemaphoreHandlerADCDriver()), &prio);
portEND_SWITCHING_ISR(prio);
Thank you!
