baiangel wrote on Tuesday, February 21, 2006:
Hi!
I am trying to use both UARTS in ATMEGA128 port of the kernel (compiled with GCC). I have the following situation: in one task, I send a message through UART0 to one node and I use xQueueReceive with timeout to receive an answer from the node. While this task is blocked on the queue, another task is sending a message to another node through UART1. The reception on both UARTS is done in an ISR. The problem is, that in this configuration the ISR is not always being entered. I have checked this using the following method: on evey entrance/exit of the ISR, I am toggling a pin of the MCU, thus counting the received symbols. With one channel of the scope I am tracing the received data (at the RX pin of the MCU) and with another channel I am tracing the toggling of the above mentioned pin. I found, that not on evey byte I get an interupt. Also, when I disable one of the tasks, transmitting through the USART, the picture is just fine. I have 4 additional tasks, so the problem is not in the count of tasks. Do you have any idea where this problem comes from? Thank you!
P.S.
I have tried this without the kernel (sending through UART0 in the main() and receiving through UART1 in an ISR). There was no such problem.
