arpitmehta wrote on Thursday, July 02, 2009:
Hi incrediball,
i have copied AT91SAM7X256.h and lib_AT91SAM7X256.h.but i am getting error as i have attached here which is from boot.s.
Severity and Description Path Resource Location Creation Time Id
undefined reference to `__bss_beg__’ encoder boot.s line 118 1246532418781 9214
undefined reference to `__data_beg__’ encoder boot.s line 118 1246532418781 9215
undefined reference to `__data_beg_src__’ encoder boot.s line 118 1246532418781 9216
undefined reference to `__data_end__’ encoder boot.s line 118 1246532418781 9217
undefined reference to `__stack_end__’ encoder boot.s line 118 1246532418781 9218
my boot.s is as below
.extern main
.extern exit
.extern AT91F_LowLevelInit
.extern vPortYieldProcessor
.text
.code 32
.align 0
.extern __stack_end__
.extern __bss_beg__
.extern __bss_end__
.extern __data_beg__
.extern __data_end__
.extern __data+beg_src__
.global start
.global endless_loop
/* Stack Sizes */
.set UND_STACK_SIZE, 0x00000004
.set ABT_STACK_SIZE, 0x00000004
.set FIQ_STACK_SIZE, 0x00000004
.set IRQ_STACK_SIZE, 0X00000400
.set SVC_STACK_SIZE, 0x00000400
/* Standard definitions of Mode bits and Interrupt (I & F) flags in PSRs */
.set MODE_USR, 0x10 /* User Mode */
.set MODE_FIQ, 0x11 /* FIQ Mode */
.set MODE_IRQ, 0x12 /* IRQ Mode */
.set MODE_SVC, 0x13 /* Supervisor Mode */
.set MODE_ABT, 0x17 /* Abort Mode */
.set MODE_UND, 0x1B /* Undefined Mode */
.set MODE_SYS, 0x1F /* System Mode */
.equ I_BIT, 0x80 /* when I bit is set, IRQ is disabled */
.equ F_BIT, 0x40 /* when F bit is set, FIQ is disabled */
start:
_start:
_mainCRTStartup:
/* Setup a stack for each mode - note that this only sets up a usable stack
for system/user, SWI and IRQ modes. Also each mode is setup with
interrupts initially disabled. */
ldr r0, .LC6
msr CPSR_c, #MODE_UND|I_BIT|F_BIT /* Undefined Instruction Mode */
mov sp, r0
sub r0, r0, #UND_STACK_SIZE
msr CPSR_c, #MODE_ABT|I_BIT|F_BIT /* Abort Mode */
mov sp, r0
sub r0, r0, #ABT_STACK_SIZE
msr CPSR_c, #MODE_FIQ|I_BIT|F_BIT /* FIQ Mode */
mov sp, r0
sub r0, r0, #FIQ_STACK_SIZE
msr CPSR_c, #MODE_IRQ|I_BIT|F_BIT /* IRQ Mode */
mov sp, r0
sub r0, r0, #IRQ_STACK_SIZE
msr CPSR_c, #MODE_SVC|I_BIT|F_BIT /* Supervisor Mode */
mov sp, r0
sub r0, r0, #SVC_STACK_SIZE
msr CPSR_c, #MODE_SYS|I_BIT|F_BIT /* System Mode */
mov sp, r0
/* We want to start in supervisor mode. Operation will switch to system
mode when the first task starts. */
bl AT91F_LowLevelInit
/* Clear BSS. */
mov a2, #0 /* Fill value */
mov fp, a2 /* Null frame pointer */
mov r7, a2 /* Null frame pointer for Thumb */
ldr r1, .LC1 /* Start of memory block */
ldr r3, .LC2 /* End of memory block */
subs r3, r3, r1 /* Length of block */
beq .end_clear_loop
mov r2, #0
.clear_loop:
strb r2, [r1], #1
subs r3, r3, #1
bgt .clear_loop
.end_clear_loop:
/* Initialise data. */
ldr r1, .LC3 /* Start of memory block */
ldr r2, .LC4 /* End of memory block */
ldr r3, .LC5
beq .end_set_loop
.set_loop:
ldrb r4, [r2], #1
strb r4, [r1], #1
subs r3, r3, #1
bgt .set_loop
.end_set_loop:
mov r0, #0 /* no arguments */
mov r1, #0 /* no argv either */
ldr lr, =main
bx lr
endless_loop:
b endless_loop
.align 0
.LC1:
.word __bss_beg__
.LC2:
.word __bss_end__
.LC3:
.word __data_beg__
.LC4:
.word __data_beg_src__
.LC5:
.word __data_end__
.LC6:
.word __stack_end__
/* Setup vector table. Note that undf, pabt, dabt, fiq just execute
a null loop. */
.section .startup,"ax"
.code 32
.align 0
b _start /* reset - _start */
ldr pc, _undf /* undefined - _undf */
ldr pc, _swi /* SWI - _swi */
ldr pc, _pabt /* program abort - _pabt */
ldr pc, _dabt /* data abort - _dabt */
nop /* reserved */
ldr pc, [pc,#-0xF20] /* IRQ - read the AIC */
ldr pc, _fiq /* FIQ - _fiq */
_undf: .word __undf /* undefined */
_swi: .word vPortYieldProcessor /* SWI */
_pabt: .word __pabt /* program abort */
_dabt: .word __dabt /* data abort */
_fiq: .word __fiq /* FIQ */
__undf: b . /* undefined */
__pabt: b . /* program abort */
__dabt: b . /* data abort */
__fiq: b . /* FIQ */
