nobody wrote on Monday, June 05, 2006:
I am trying to run the Freertos demo for at90can128 on IAR compiler. I made some changes related to uart and timer registers accordying to the documentation. I try to run a board with avrstuido and some createtasks (those related to serial port on comtest.c) return errCOULD_NOT_ALLOCATE_REQUIRED_MEMORY. The flash led task works ok…
Does anyone have some kind of solution or suggestion for this problem?
