Hi!
I am working with AT90CAN128 and IAR and external memory. The AT90CAN128 has some bug on "Miss-functioning when code stack is in XRAM" so I must put the heap only in internal RAM. How can I do that in IAR and what variables location I need to change?
Thanks for some help!
In GCC you can define the section that any data item goes in using an attribute ((section…)) style. Some compilers you can do the same using a #pragma. I expect you will have to setup a section in your linker for you different memory areas (probably already so) then use a pragma or attribute on the data to say which section it should go in. Can IAR do this?
