schmidtw wrote on Sunday, May 04, 2008:
I just downloaded FreeRTOS 5.0.0 and tried to build with the latest avr32-* GNU toolchain from Atmel & got several compile errors. It looks like the Atmel header files possibly changed.
First try:
$ make clean
$ make
Compiling `…/…/BOARDS/EVK1100/led.c’ to `…/…/BOARDS/EVK1100/led.o’.
…/…/BOARDS/EVK1100/led.c:77: error: ‘AVR32_PWM_PWM_0_FUNCTION’ undeclared here (not in a function)
…/…/BOARDS/EVK1100/led.c:77: error: ‘AVR32_PWM_PWM_1_FUNCTION’ undeclared here (not in a function)
…/…/BOARDS/EVK1100/led.c:77: error: ‘AVR32_PWM_PWM_2_FUNCTION’ undeclared here (not in a function)
…/…/BOARDS/EVK1100/led.c:77: error: ‘AVR32_PWM_PWM_3_FUNCTION’ undeclared here (not in a function)
make: *** […/…/BOARDS/EVK1100/led.o] Error 1
So in evk1100.h I changed AVR32_PWM_PWM_x_FUNCTION to AVR32_PWM_x_FUNCTION - problem solved.
Second try:
$ make clean
$ make
Compiling `…/…/DRIVERS/INTC/intc.c’ to `…/…/DRIVERS/INTC/intc.o’.
…/…/DRIVERS/INTC/intc.c:52: error: ‘AVR32_INTC_IPR0_INTLEV_SIZE’ undeclared here (not in a function)
…/…/DRIVERS/INTC/intc.c: In function ‘_get_interrupt_handler’:
…/…/DRIVERS/INTC/intc.c:111: error: ‘avr32_intc_t’ has no member named ‘icr3’
…/…/DRIVERS/INTC/intc.c: In function ‘INTC_register_interrupt’:
…/…/DRIVERS/INTC/intc.c:199: error: ‘AVR32_INTC_IPR0_INTLEV_MASK’ undeclared (first use in this function)
…/…/DRIVERS/INTC/intc.c:199: error: (Each undeclared identifier is reported only once
…/…/DRIVERS/INTC/intc.c:199: error: for each function it appears in.)
…/…/DRIVERS/INTC/intc.c:199: error: ‘AVR32_INTC_IPR0_INTLEV_OFFSET’ undeclared (first use in this function)
make: *** […/…/DRIVERS/INTC/intc.o] Error 1
This time I’m not sure what AVR32_INTC_IPR0_INTLEV_SIZE should be mapped to.
Any ideas?
Here are the avr32 versions I’m using:
avr32parts-1.9.9-1.fc8
avr32-gdb-6.7.1.atmel.1.0.3-1.fc8
avr32headers-1.9.11-1.fc8
avr32program-3.0.4-1.fc8
avr32-binutils-2.17.atmel.1.2.6-1.fc8
libavr32ocd-3.0.8-1.fc8
avr32trace-2.0.3-1.fc8
libavr32sim-0.2.1-1.fc8
avr32-gcc-newlib-4.2.2-atmel.1.0.8_1.fc8
avr32gdbproxy-3.0.11-1.fc8
Thanks,
Wes
