Hi
I made a boo boo on a call to xTaskCreate where I somehow managed to set the prio to the same value as the stack size that happend to be 208. As my configMAX_PRIORITIES was set to 9 this reduced my prio on the task to 8 and everything work the way it was intended to according to the documentation of xTaskCreate. Basically, if you set a way too high prio, it will be reduced to the highest allowed in the system. However the vTaskPrioritySet function does the same thing but it also includes a call configASSERT( ( uxNewPriority < configMAX_PRIORITIES ) ); Could that assert not also be added to xTaskCreate?
Best regards
Martin
