Hi, I am trying to read and understand the MPU related part. The FreeRTOS version is 10.5.1, and I am using \portable\IAR\ARM_CM4F_MPU.
In the “port.c” file, Line 596, function “prvSetupMPU”. I can see we are trying to setup MPU for the unprivileged flash, privileged flash, privileged data RAM region and peripherals. What confuse me is that we are writing all their attribute(RBAR and RASR) in the same address(portMPU_REGION_BASE_ADDRESS_REG and portMPU_REGION_ATTRIBUTE_REG).
When will the data written first be used? Will it not be overwritten by data written later?
static void prvSetupMPU( void )
extern uint32_t __privileged_functions_start__[];
extern uint32_t __privileged_functions_end__[];
extern uint32_t __FLASH_segment_start__[];
extern uint32_t __FLASH_segment_end__[];
extern uint32_t __privileged_data_start__[];
extern uint32_t __privileged_data_end__[];
/* The only permitted number of regions are 8 or 16. */
configASSERT( ( configTOTAL_MPU_REGIONS == 8 ) || ( configTOTAL_MPU_REGIONS == 16 ) );
/* Ensure that the configTOTAL_MPU_REGIONS is configured correctly. */
configASSERT( portMPU_TYPE_REG == portEXPECTED_MPU_TYPE_VALUE );
/* Check the expected MPU is present. */
if( portMPU_TYPE_REG == portEXPECTED_MPU_TYPE_VALUE )
/* First setup the unprivileged flash for unprivileged read only access. */
portMPU_REGION_BASE_ADDRESS_REG = ( ( uint32_t ) __FLASH_segment_start__ ) | /* Base address. */
( portMPU_REGION_VALID ) |
( portUNPRIVILEGED_FLASH_REGION );
portMPU_REGION_ATTRIBUTE_REG = ( portMPU_REGION_READ_ONLY ) |
( ( configTEX_S_C_B_FLASH & portMPU_RASR_TEX_S_C_B_MASK ) << portMPU_RASR_TEX_S_C_B_LOCATION ) |
( prvGetMPURegionSizeSetting( ( uint32_t ) __FLASH_segment_end__ - ( uint32_t ) __FLASH_segment_start__ ) ) |
( portMPU_REGION_ENABLE );
/* Setup the privileged flash for privileged only access. This is where
* the kernel code is placed. */
portMPU_REGION_BASE_ADDRESS_REG = ( ( uint32_t ) __privileged_functions_start__ ) | /* Base address. */
( portPRIVILEGED_FLASH_REGION );
portMPU_REGION_ATTRIBUTE_REG = ( portMPU_REGION_PRIVILEGED_READ_ONLY ) |
( prvGetMPURegionSizeSetting( ( uint32_t ) __privileged_functions_end__ - ( uint32_t ) __privileged_functions_start__ ) ) |
/* Setup the privileged data RAM region. This is where the kernel data
* is placed. */
portMPU_REGION_BASE_ADDRESS_REG = ( ( uint32_t ) __privileged_data_start__ ) | /* Base address. */
( portPRIVILEGED_RAM_REGION );
portMPU_REGION_ATTRIBUTE_REG = ( portMPU_REGION_PRIVILEGED_READ_WRITE ) |
( portMPU_REGION_EXECUTE_NEVER ) |
( ( configTEX_S_C_B_SRAM & portMPU_RASR_TEX_S_C_B_MASK ) << portMPU_RASR_TEX_S_C_B_LOCATION ) |
prvGetMPURegionSizeSetting( ( uint32_t ) __privileged_data_end__ - ( uint32_t ) __privileged_data_start__ ) |
/* By default allow everything to access the general peripherals. The
* system peripherals and registers are protected. */
portMPU_REGION_BASE_ADDRESS_REG = ( portPERIPHERALS_START_ADDRESS ) |
( portGENERAL_PERIPHERALS_REGION );
portMPU_REGION_ATTRIBUTE_REG = ( portMPU_REGION_READ_WRITE | portMPU_REGION_EXECUTE_NEVER ) |
( prvGetMPURegionSizeSetting( portPERIPHERALS_END_ADDRESS - portPERIPHERALS_START_ADDRESS ) ) |
/* Enable the memory fault exception. */
portNVIC_SYS_CTRL_STATE_REG |= portNVIC_MEM_FAULT_ENABLE;
/* Enable the MPU with the background region configured. */
portMPU_CTRL_REG |= ( portMPU_ENABLE | portMPU_BACKGROUND_ENABLE );
By the way, I have another question but that might be more ARM related. According to “ARM Cortex™-M4 Devices Generic User Guide”, MPU_RBAR (portMPU_REGION_BASE_ADDRESS_REG) have 3 alias of RBAR called, MPU_RBAR_A1, MPU_RBAR_A2, MPU_RBAR_A3. I am not sure what is their usage. They have 4 different address but seems update at the same time, all the data write into MPU_RBAR will be written into its 3 alias registers. I’d greatly appreciate it if you could help me understand this part.
