guggech wrote on Wednesday, April 04, 2018:
When I try to compile the Cortex_M4F_ATSAM4E_Atmel_Studio demo, I get a compile error that state it cannot find “fat_sl.h” file. Any idea?
Thanks,
Charles
Thanks,
Charles
rtel wrote on Wednesday, April 04, 2018:
Ah - right - FreeRTOS V10.x downloads don’t include the FAT SL product.
I would suggest downloading the last V9.x version, then just copying the
FreeRTOS V10 source files over the top of the V9 source files.
guggech wrote on Thursday, April 05, 2018:
Thank you for the reply. I downloaded the 9.0 version and copied the 10.0 over and still having some missing files. I deleted the 9.0 and 10.0 folder and tried again fresh. Now I am getting the following message when compiling:
No Rule to make target ‘src/asf/thirdparty/FreeRTOS/event_groups.o’, needed by ‘RTOSDemo.elf’
Looking at the project, all the files under the Common-Demo-Source folder are missing.
rtel wrote on Thursday, April 05, 2018:
I’m not sure I understand - I only intended that you replace the
FreeRTOS source files, those under FreeRTOS/Source in the FreeRTOS
kernel distribution - although they may be somewhere else in your
project. You should not have changed anything in the demo directories.
Also both FreeRTOS V9.x and V10.x both have event_groups.c in the same
location so I’m not sure why it would be missing now.
After having re-loaded the V10.x and running the “CreateProjectDirectoryStructure.bat” in the Cortex_M4_ATSAM4S_Atmel_Studio folder, all the needed file are there and I can compile the project. I can step thru the code but I have not being able to have the tasks blink the LED. It apprears that the taskl tick is not running. Still investigating…
Thank You.
By the way I am using the SAM4S Xplained Pro evaluation board…
