kg7hf wrote on Thursday, May 24, 2018:
Many of the ARM Cortex M0+ processors also support the MPU capability like their big brother/sister the M4 and M3. However, I do not see a port that will enable the MPU capability for the M0+. Does one exist?
rtel wrote on Thursday, May 24, 2018:
I think somebody created one a long time ago - you may find reference in
the support forum archive or in the FreeRTOS Interactive site. Other
than that, if the MPU is the same as per the Cortex-M3/4/7 then you
should be able to merge the MPU ports for those chips with the M0 port.
Thanks, I’ll do some searching, it is supposed to be the same as the M3/M4. If we end up with a port, do we submit it back for inclusion?
rahmanih wrote on Friday, October 05, 2018:
Hi Paul,
Did you succeed to find something about it?
regards
Haithem.
