Hi Team,
We are working on an application in which we are using the NXP S32146 Evaluation board to integrate the FreeRTOS into our application.
We have integrated the whole folder structure into out software stack. The problem arises at line #57 of the core file port.asm (stmdb r0!, {r4-r11, r14}), #77 (ldmia r0!, {r4-r11, r14}).
The hardware supports ARM_CM4F but the instruction set used in the file mentioned above relates to ARM_CM7 which causes a problem.
To proceed further with my implementation I have changed the core from ARM_CM4F to ARM_CM3 the issue is resolved, but going further the application demands FPU, but VFP instruction is not supported by ARM_CM3. Can you please suggest an solution for the same
Version of the FreeRTOS port used is FreeRTOS Kernel V10.2.1.
Regards,
Karthic
