Everything works perfectly, but a few minutes after booting, when the system is mostly idle, then my vPortSuppressTicksAndSleep is called with a very large xExpectedIdleTime of 648326 ticks (or ms).
This is very strange, as there is is a task ‘vBusHeartbeatTask’ that sends a bus message once per minute, and so would expect a maximum xExpectedIdleTime of only 60000 ticks
Hmm, that is going to be a tricky one to debug remotely. To start with
I would have two suggestions - first would be to use the latest version
of FreeRTOS, it should be a drop in replaced. Next would be to set a
break point when the large value i seen so we can try and see where it
comes from. That would involve some pretty deep diving into the data
structures within the kernel.
I updated to v10.2, which made no difference. I then had to create a simulated sleep (basically a NOP loop) because the MCU sleep mode breaks the debugger. Finally, I found the issue. I was using the RTC second alarm as a wake up source. The wake-up resolution is 1-sec, but the RTC input clock comes from a pre-scaler, which is fed at 32768Hz. This means the second counter could tick over any time between 1/32768 and 1 sec. It seems that my sloppy arithmetic…
…was the problem, as it was unlikely that 1000ms had actually passed since the alarm was set. Cosnsequently, vTaskStepTick incremented the tick to a value that was too large, such that the waiting task was deemed to have run, and it would be a very long time before the tick counter came around again. The subsequent call to vPortSuppressTicksAndSleep then reflected this with an abnormally large xExpectedIdleTime. To test the theory I simply increased the expected idle time config…
