hjmagadum2002 wrote on Monday, May 20, 2013:
I integrated ARM 7 SAM7x512 code with latest freertos . But after changing following in 256.h.
code showing no definition error
Modification is
/*#define AT91C_ISRAM ((char *) 0x00200000) // Internal SRAM base address
#define AT91C_ISRAM_SIZE ((unsigned int) 0x00010000) // Internal SRAM size in byte (64 Kbyte)
#define AT91C_IFLASH ((char *) 0x00100000) // Internal ROM base address
#define AT91C_IFLASH_SIZE ((unsigned int) 0x00040000) // Internal ROM size in byte (256 Kbyte)*/
------Above commented things replaced with below items
#define AT91C_ISRAM (0x00200000) // Internal SRAM base address
//#define AT91C_ISRAM_SIZE (0x00010000) // Internal SRAM size in byte (64 Kbytes)
#define AT91C_ISRAM_SIZE (0x00020000) // Internal SRAM size in byte (128 Kbytes)
// IFLASH
#define AT91C_IFLASH (0x00100000) // Internal FLASH base address
#define AT91C_IFLASH_SIZE (0x00080000) // Internal FLASH size in byte (256 Kbytes)
#define AT91C_IFLASH_PAGE_SIZE (256) // Internal FLASH Page Size: 256 bytes
#define AT91C_IFLASH_LOCK_REGION_SIZE (16384) // Internal FLASH Lock Region Size: 16 Kbytes
#define AT91C_IFLASH_NB_OF_PAGES (2048) // Internal FLASH Number of Pages: 1024 bytes
#define AT91C_IFLASH_NB_OF_LOCK_BITS (32) // Internal FLASH Number of Lock Bits: 16 bytes
error is-----
Error: no definition for “tapdev_send”
