anonymous wrote on Thursday, April 19, 2012:
I am using the freeRTOS port on a LPC1763 M3 chip. Everything was working great until yesterday when I added a new global variable for tracking errors. I was finding that the errorflags were getting overwritten (with what looks to me to be a memory address). So I set a breakpoint to fire whenever that location got written to or read from and I found that the line that does it is line 98 in list.c:
pxIndex = pxList->pxIndex;
I haven’t confirmed this, but it appears to always happen after sending a sempahore from my serial ISR:
xSemaphoreGiveFromISR( pUartCtl_s->xRxDataAvailSema, &xTaskWoken );
This line has been there for months though, and never had a problem until I introduced the new global error flag. So Im unsure as to how this line could be wrong. I tried increasing my stacksize, but that didnt seem to help the problem at all.
I know this is not a lot of information, but im confused enough to not know what information would be helpful in this case. Here are some of my current freertosconfig defines if that helps.
#define configUSE_IDLE_HOOK 0
#define configMAX_PRIORITIES ( ( unsigned portBASE_TYPE ) 6 )
#define configUSE_TICK_HOOK 0 // WAS 1 dks
// FULL_SPEED can be set in Rowley CrossStudio Common Private property “Preprocessor Definitions” under Project Properties.
#ifdef FULL_SPEED
#define configCPU_CLOCK_HZ ( ( unsigned long ) 100000000 )
#else
#define configCPU_CLOCK_HZ ( ( unsigned long ) 72000000 )
#define configTICK_RATE_HZ ( ( portTickType ) 1000 )
// This next #define sets the default task stack size in 32-bit words
#define configMINIMAL_STACK_SIZE ( ( unsigned short ) 100 )
#define configTOTAL_HEAP_SIZE ( ( size_t ) ( 20 * 1024 ) )
#define configMAX_TASK_NAME_LEN ( 12 )
#define configIDLE_SHOULD_YIELD 0
#define configUSE_MUTEXES 1
#define configMAX_CO_ROUTINE_PRIORITIES ( 2 )
#define configUSE_COUNTING_SEMAPHORES 0
Thanks for your help!
#define configUSE_ALTERNATIVE_API 0
#define configUSE_RECURSIVE_MUTEXES 1
#define configQUEUE_REGISTRY_SIZE 10
#define configGENERATE_RUN_TIME_STATS 0
#define INCLUDE_vTaskPrioritySet 1
#define INCLUDE_uxTaskPriorityGet 1
#define INCLUDE_vTaskDelete 1
#define INCLUDE_vTaskCleanUpResources 0
#define INCLUDE_vTaskDelayUntil 1
#define INCLUDE_vTaskDelay 1
#define INCLUDE_uxTaskGetStackHighWaterMark 1
/* Use the system definition, if there is one */
#ifdef __NVIC_PRIO_BITS
#define configPRIO_BITS __NVIC_PRIO_BITS
#else
#define configPRIO_BITS 5 /* 32 priority levels */
/* The lowest priority. */
#define configKERNEL_INTERRUPT_PRIORITY ( 31 << (8 - configPRIO_BITS) )
/* Priority 5, or 160 as only the top three bits are implemented. */
#define configMAX_SYSCALL_INTERRUPT_PRIORITY ( 5 << (8 - configPRIO_BITS) )
/* Priorities passed to NVIC_SetPriority() do not require shifting as the
function does the shifting itself. Note these priorities need to be equal to
or lower than configMAX_SYSCALL_INTERRUPT_PRIORITY - therefore the numeric
value needs to be equal to or greater than 5 (on the Cortex-M3 the lower the
numeric value the higher the interrupt priority). */
#define MX_UART_INT_PRIORITY 6
#define RIT_FOR_COUNTERS_INT_PRIORITY 7
#define TIMER2_INT_PRIORITY 7
#define TIMER3_INT_PRIORITY 7
#define configEMAC_INTERRUPT_PRIORITY 5
#define configUSB_INTERRUPT_PRIORITY 6
