I have a project (carlk3/FreeRTOS-FAT-CLI-for-RPi-Pico) running on the official SMP FreeRTOS RP2040 port (FreeRTOS/FreeRTOS-Kernel) on Raspberry Pi Pico.
I have successfully tested running five Tasks running on two cores simultaneously doing I/O to two SD cards. I did this by modifying vMultiTaskStdioWithCWDTest in FreeRTOS-Plus/FreeRTOS-Plus/Demo/Common/FreeRTOS_Plus_FAT_Demos/test/ff_stdio_tests_with_cwd.c to write to two different mountpoints. It looks something like this:
vCreateAndVerifyExampleFiles(pcMountPath=/sd0/0)
prvCreateDemoFilesUsing_ff_fwrite(pcMountPath=/sd0/0)
core0: FS0: Creating file root001.txt in /sd0/0
vCreateAndVerifyExampleFiles(pcMountPath=/sd0/2)
prvCreateDemoFilesUsing_ff_fwrite(pcMountPath=/sd0/2)
core1: FS2: Creating file root001.txt in /sd0/2
vCreateAndVerifyExampleFiles(pcMountPath=/sd1/1)
prvCreateDemoFilesUsing_ff_fwrite(pcMountPath=/sd1/1)
core0: FS1: Creating file root001.txt in /sd1/1
vCreateAndVerifyExampleFiles(pcMountPath=/sd1/3)
prvCreateDemoFilesUsing_ff_fwrite(pcMountPath=/sd1/3)
core0: FS3: Creating file root001.txt in /sd1/3
core1: FS0: Creating file root002.txt in /sd0/0
core0: FS2: Creating file root002.txt in /sd0/2
core1: FS1: Creating file root002.txt in /sd1/1
core0: FS3: Creating file root002.txt in /sd1/3
vCreateAndVerifyExampleFiles(pcMountPath=/sd0/4)
prvCreateDemoFilesUsing_ff_fwrite(pcMountPath=/sd0/4)
core0: FS2: Creating file root003.txt in /sd0/2
core1: FS4: Creating file root001.txt in /sd0/4
core1: FS0: Creating file root003.txt in /sd0/0
core0: FS1: Creating file root003.txt in /sd1/1
core1: FS2: Creating file root004.txt in /sd0/2
core0: FS3: Creating file root003.txt in /sd1/3
core0: FS4: Creating file root002.txt in /sd0/4
core1: FS0: Creating file root004.txt in /sd0/0
core0: FS1: Creating file root004.txt in /sd1/1
core0: FS4: Creating file root003.txt in /sd0/4
core0: FS3: Creating file root004.txt in /sd1/3
core0: FS2: Creating file root005.txt in /sd0/2
core1: FS0: Creating file root005.txt in /sd0/0
core0: FS1: Creating file root005.txt in /sd1/1
core0: FS4: Creating file root004.txt in /sd0/4
core1: FS3: Creating file root005.txt in /sd1/3
prvVerifyDemoFileUsing_ff_fread()
core1: FS2: Reading file root001.txt from /sd0/2
core0: FS1: Reading file root001.txt from /sd1/1
core1: FS2: FF_fopen(root001.txt): Success (0)
core1: FS0: Reading file root001.txt from /sd0/0
core0: FS1: FF_fopen(root001.txt): Success (0)
core0: FS0: FF_fopen(root001.txt): Success (0)
core1: FS2: Reading file root002.txt from /sd0/2
core0: FS1: Reading file root002.txt from /sd1/1
core0: FS4: Creating file root005.txt in /sd0/4
core0: FS0: Reading file root002.txt from /sd0/0
core1: FS1: FF_fopen(root002.txt): Success (0)
core0: FS3: Reading file root001.txt from /sd1/3
core1: FS2: FF_fopen(root002.txt): Success (0)
core0: FS1: Reading file root003.txt from /sd1/1
core1: FS0: FF_fopen(root002.txt): Success (0)
core1: FS3: FF_fopen(root001.txt): Success (0)
core0: FS2: Reading file root003.txt from /sd0/2
core0: FS1: FF_fopen(root003.txt): Success (0)
core1: FS0: Reading file root003.txt from /sd0/0
core0: FS2: FF_fopen(root003.txt): Success (0)
core0: FS3: Reading file root002.txt from /sd1/3
core0: FS1: Reading file root004.txt from /sd1/1
core0: FS4: Reading file root001.txt from /sd0/4
core0: FS0: FF_fopen(root003.txt): Success (0)
core0: FS2: Reading file root004.txt from /sd0/2
core0: FS3: FF_fopen(root002.txt): Success (0)
core0: FS1: FF_fopen(root004.txt): Success (0)
core1: FS4: FF_fopen(root001.txt): Success (0)
core0: FS0: Reading file root004.txt from /sd0/0
core0: FS2: FF_fopen(root004.txt): Success (0)
core0: FS3: Reading file root003.txt from /sd1/3
core0: FS1: Reading file root005.txt from /sd1/1
core0: FS4: Reading file root002.txt from /sd0/4
core0: FS0: FF_fopen(root004.txt): Success (0)
core0: FS2: Reading file root005.txt from /sd0/2
core0: FS3: FF_fopen(root003.txt): Success (0)
core0: FS1: FF_fopen(root005.txt): Success (0)
core1: FS4: FF_fopen(root002.txt): Success (0)
prvCreateDemoFileUsing_ff_fputc(pcMountPath=/sd1/1)
core1: FS0: Reading file root005.txt from /sd0/0
core0: FS2: FF_fopen(root005.txt): Success (0)
core0: FS3: Reading file root004.txt from /sd1/3
prvCreateDemoFileUsing_ff_fputc(pcMountPath=/sd0/2)
core1: FS4: Reading file root003.txt from /sd0/4
core0: FS1: In directory /sd1/1
core0: FS0: FF_fopen(root005.txt): Success (0)
core0: FS3: FF_fopen(root004.txt): Success (0)
core1: FS2: In directory /sd0/2
core0: FS4: FF_fopen(root003.txt): Success (0)
prvCreateDemoFileUsing_ff_fputc(pcMountPath=/sd0/0)
core1: FS0: In directory /sd0/0
core1: FS4: Reading file root004.txt from /sd0/4
core0: FS3: Reading file root005.txt from /sd1/3
core1: FS4: FF_fopen(root004.txt): Success (0)
core1: FS3: FF_fopen(root005.txt): Success (0)
core1: FS4: Reading file root005.txt from /sd0/4
prvCreateDemoFileUsing_ff_fputc(pcMountPath=/sd1/3)
core1: FS3: In directory /sd1/3
core1: FS4: FF_fopen(root005.txt): Success (0)
prvCreateDemoFileUsing_ff_fputc(pcMountPath=/sd0/4)
core1: FS4: In directory /sd0/4
core0: FS1: In directory /sd1/1/SUB1
core0: FS2: In directory /sd0/2/SUB1
core0: FS0: In directory /sd0/0/SUB1
core0: FS3: In directory /sd1/3/SUB1
core0: FS4: In directory /sd0/4/SUB1
core0: FS1: In directory /sd1/1/SUB1/SUB2
core1: FS1: Writing file SUB2.txt in /sd1/1/SUB1/SUB2
core1: FS2: In directory /sd0/2/SUB1/SUB2
core1: FS2: Writing file SUB2.txt in /sd0/2/SUB1/SUB2
core1: FS0: In directory /sd0/0/SUB1/SUB2
core1: FS0: Writing file SUB2.txt in /sd0/0/SUB1/SUB2
core0: FS3: In directory /sd1/3/SUB1/SUB2
core0: FS3: Writing file SUB2.txt in /sd1/3/SUB1/SUB2
core0: FS2: Back in root directory /sd0/2
prvVerifyDemoFileUsing_ff_fgetc(pcMountPath=/sd0/2)
core0: FS1: Back in root directory /sd1/1
prvVerifyDemoFileUsing_ff_fgetc(pcMountPath=/sd1/1)
core0: FS4: In directory /sd0/4/SUB1/SUB2
core0: FS0: Back in root directory /sd0/0
core0: FS4: Writing file SUB2.txt in /sd0/4/SUB1/SUB2
prvVerifyDemoFileUsing_ff_fgetc(pcMountPath=/sd0/0)
core1: FS2: Back in directory /sd0/2/SUB1/SUB2
core0: FS2: Reading file SUB2.txt in /sd0/2/SUB1/SUB2
core0: FS1: Back in directory /sd1/1/SUB1/SUB2
core1: FS1: Reading file SUB2.txt in /sd1/1/SUB1/SUB2
core0: FS0: Back in directory /sd0/0/SUB1/SUB2
core1: FS0: Reading file SUB2.txt in /sd0/0/SUB1/SUB2
core0: FS3: Back in root directory /sd1/3
prvVerifyDemoFileUsing_ff_fgetc(pcMountPath=/sd1/3)
core1: FS2: Back in root directory /sd0/2
core1: FS2: vStdioWithCWDTest(pcMountPath=/sd0/2)
core1: FS3: Back in directory /sd1/3/SUB1/SUB2
core1: FS3: Reading file SUB2.txt in /sd1/3/SUB1/SUB2
core1: FS1: vStdioWithCWDTest(pcMountPath=/sd1/1)
core1: FS4: Back in root directory /sd0/4
prvVerifyDemoFileUsing_ff_fgetc(pcMountPath=/sd0/4)
core0: FS4: Back in directory /sd0/4/SUB1/SUB2
core0: FS0: vStdioWithCWDTest(pcMountPath=/sd0/0)
core0: FS3: vStdioWithCWDTest(pcMountPath=/sd1/3)
core0: FS4: Reading file SUB2.txt in /sd0/4/SUB1/SUB2
core1: FS4: vStdioWithCWDTest(pcMountPath=/sd0/4)
task-stats
Task State Priority Stack #
stdio Task X 3 453 1
FS2 R 2 264 7
FS0 R 2 246 5
FS3 R 2 246 8
IDLE0 X 0 107 3
IDLE1 R 0 109 4
FS4 B 2 246 9
FS1 B 2 246 6
Tmr Svc B 4 88 2
> run-time-stats
Task Abs Time % Time
stdio Task 80524 5%
FS2 210801 13%
FS0 200522 13%
FS3 196209 12%
IDLE0 237457 15%
IDLE1 222973 14%
FS4 197284 12%
FS1 193478 12%
Tmr Svc 129 <1%
