I´m trying to develop a Greengrass solution using a STM32f072 micro as AWS IoT device and a Raspberry Pi as GGC. My question is: Is it possible to use Amazon FreeRTOS in an STM32f0 device in order to connect it to the Greengrass core?. I´ve been checking around and it should work with STM32 (Cortex M4 based) but no idea if possible in a ARM Cortex M0 based or what to do with this HW.
I see that those STM32f0 are varying widely in RAM, but even with the 32kb model it is going to be challenging.
FreeRTOS itself is very small:https://www.freertos.org/FAQMem.html
5 to 10 KBytes of flash space and a few bytes of RAM
To interact with GG you will need at least the following libraries
GG
MQTT
FreeRTOS kernel
TCP/IP
MBEDTLS
GG and MQTT will consume a 2-4K of RAM, depending on the size of the buffers you set.
TCP/IP mbedTLS will consume much more 50-70K depending on the target.
If you use STM32F0 it might be possible if the model is 32K of RAM but you will probably need to use an external TCP/IP stack.
