I am running AFQ MQTT test. When I unplug the network cable from my network switch, all the test items would also pass.
This is strange… I thought MQTT test is supposed to test for actual connection with the IoT Cloud? Why are all the test past even without network connection?
In regards to version 1.4.8, the tests under Full_MQTT do not connect to AWS IoT. These tests verify functionality of library code with some mocked data. These tests have been deleted in the latest version.
If you would like to test your connect to AWS IoT, you must use:
testrunnerFULL_MQTT_AGENT_ENABLED
testrunnerFULL_MQTT_ALPN_ENABLED
testrunnerFULL_MQTT_STRESS_TEST_ENABLED
