Hi.
The link to the “Adding FreeRTOS-Plus-TCP To a FreeRTOS Project” topic is broken.
I’m trying to use the FreeRTOS-Plus-TCP in my project, but this critical section is not working.
Can you please fix it?
Hi @michaelv
Thanks for pointing out the issue. We will work on getting it back up ASAP
while we work on getting the page back, here is archived link to that page: https://web.archive.org/web/20240424164857/https://freertos.org/FreeRTOS-Plus/FreeRTOS_Plus_TCP/TCP_Networking_Tutorial_Adding_Source_Files.html
Thank you very much. It helps a lot
The page is now working, thanks for reporting the issue.
