Prakash
(Prakash)
March 29, 2021, 2:23pm
1
I have been trying to add a 3rd party library into AWS freertos and I tried tried adding it to /vendors/espressif/esp-idf/components/ and also under libraries/3rdparty but am failing to port it fully (maybe due to Cmakelists.txt).
I am trying to port this library
Please help me out.
Thanks in advance.
hs2
(Hartmut Schaefer)
March 29, 2021, 2:32pm
2
You should add what exactly you’ve tried so far and describe/post the problem. That provides a better starting point for others to help.
Prakash
(Prakash)
March 29, 2021, 3:15pm
3
So in libraries/3rdparty/Cmakelist.txt I added this part
if(EXISTS "${AFR_3RDPARTY_DIR}/depthai-spi-api")
set(depthai-spi-api_src
"${AFR_3RDPARTY_DIR}/depthai-spi-api/depthai-shared/src/datatype/DatatypeEnum.cpp"
"${AFR_3RDPARTY_DIR}/depthai-spi-api/depthai-shared/src/general/data_writer.cpp"
"${AFR_3RDPARTY_DIR}/depthai-spi-api/depthai-shared/src/logger/logs_writer.cpp"
"${AFR_3RDPARTY_DIR}/depthai-spi-api/depthai-shared/src/stream/stream_info.cpp"
"${AFR_3RDPARTY_DIR}/depthai-spi-api/depthai-shared/src/xlink/xlink_wrapper.cpp"
"${AFR_3RDPARTY_DIR}/depthai-spi-api/depthai-shared/src/disparity_luts.cpp"
"${AFR_3RDPARTY_DIR}/depthai-spi-api/depthai-shared/src/json_helper.cpp"
"${AFR_3RDPARTY_DIR}/depthai-spi-api/common/nlohmann/json.hpp"
"${AFR_3RDPARTY_DIR}/depthai-spi-api/common/decode_raw_mobilenet.c"
"${AFR_3RDPARTY_DIR}/depthai-spi-api/common/decode_raw_mobilenet.h"
"${AFR_3RDPARTY_DIR}/depthai-spi-api/common/esp32_spi_impl.c"
"${AFR_3RDPARTY_DIR}/depthai-spi-api/common/esp32_spi_impl.h"
"${AFR_3RDPARTY_DIR}/depthai-spi-api/spi_api.hpp"
"${AFR_3RDPARTY_DIR}/depthai-spi-api/spi_api.cpp"
add_library(
afr_3rdparty_depthai-spi-api STATIC EXCLUDE_FROM_ALL
${depthai-spi-api_src}
target_sources(
PRIVATE
target_include_directories(
PUBLIC
"${AFR_3RDPARTY_DIR}/depthai-spi-api/depthai-shared/src"
target_link_libraries(
PRIVATE AFR::compiler::mcu_port
target_compile_options(
PRIVATE
$<$<C_COMPILER_ID:GNU>:-w>
add_library(3rdparty::depthai-spi-api ALIAS afr_3rdparty_depthai-spi-api)
endif()
And I added in #include “decode_raw_mobilenet.h” in vendors/espressif/boards/esp32/aws_demos/application_code/main.c which is throwing the error “fatal error: decode_raw_mobilenet.h: No such file or directory
#include “decode_raw_mobilenet.h””
hs2
(Hartmut Schaefer)
March 29, 2021, 3:28pm
4
Maybe I’m completely wrong shouldn’t you set ${AFR_3RDPARTY_DIR}/depthai-spi-api/common in target_include_directories ?
Prakash
(Prakash)
March 29, 2021, 3:56pm
5
Thank you @hs2
It worked by adding the following block in /vendors/espressif/boards/esp32/CMakeLists.txt
AFR::kernel::mcu_port
INTERFACE
${kernel_inc_dirs}
"${AFR_KERNEL_DIR}/portable/ThirdParty/GCC/Xtensa_ESP32/include/"
"${aws_credentials_include}"
"${board_dir}/config_files"
"$<$<NOT:${AFR_METADATA_MODE}>:${CMAKE_BINARY_DIR}/config>"
hs2
(Hartmut Schaefer)
March 29, 2021, 6:03pm
6
Thanks @Prakash for reporting back your solution !
Hermiston
(Hermiston)
April 19, 2021, 3:28am
7
I am facing the same issue. Please keep suggesting such answer to my issue.
MyAARPMedicare
Prakash
(Prakash)
April 19, 2021, 10:24am
8
As suggested by @hs2 I added library directory paths in target_include_directories and also the library files under target_sources
Something like
target_sources(
INTERFACE
"${AFR_3RDPARTY_DIR}/depthai-spi-api/common/xxx.cpp"
"${AFR_3RDPARTY_DIR}/depthai-spi-api/depthai-shared/yyy.cpp"
"${AFR_3RDPARTY_DIR}/depthai-spi-api/depthai-spi-library/zzz.cpp"
