eibach wrote on Thursday, October 08, 2009:
I needed to get the handle of a task from the number shown by vTaskList(). So I added xTaskGetHandle().
Cheers
Dirk
<pre><code>
diff -pur FreeRTOS/Source/include/task.h …/…/neo-lwl/FreeRTOS/Source/include/task.h
– FreeRTOS/Source/include/task.h 2009-08-09 19:55:50.000000000 +0200
+++ …/…/neo-lwl/FreeRTOS/Source/include/task.h 2009-10-08 14:09:51.051501389 +0200
@@ -1058,6 +1058,11 @@ void vTaskSwitchContext( void );
xTaskHandle xTaskGetCurrentTaskHandle( void );
+ * Return the handle of the task identified by uNumber.
+xTaskHandle xTaskGetTaskHandle( unsigned portBASE_TYPE uNumber );
* Capture the current time status for future reference.
void vTaskSetTimeOutState( xTimeOutType * const pxTimeOut );
diff -pur FreeRTOS/Source/tasks.c …/…/neo-lwl/FreeRTOS/Source/tasks.c
– FreeRTOS/Source/tasks.c 2009-08-09 19:55:50.000000000 +0200
+++ …/…/neo-lwl/FreeRTOS/Source/tasks.c 2009-10-08 14:35:24.775001569 +0200
@@ -82,6 +82,7 @@ typedef struct tskTaskControlBlock
#if ( configUSE_TRACE_FACILITY == 1 )
unsigned portBASE_TYPE uxTCBNumber; /*< This is used for tracing the scheduler and making debugging easier only. */
+ xListItem xFullListItem;
#if ( configUSE_MUTEXES == 1 )
@@ -132,6 +133,12 @@ static xList xPendingReadyList; /*
+ #if ( configUSE_TRACE_FACILITY == 1 )
+ static xList xFullTaskList; /*< All tasks */
+ #endif
/* File private variables. ---------------------*/
static volatile unsigned portBASE_TYPE uxCurrentNumberOfTasks = ( unsigned portBASE_TYPE ) 0;
static volatile portTickType xTickCount = ( portTickType ) 0;
@@ -446,6 +453,7 @@ tskTCB * pxNewTCB;
/* Add a counter into the TCB for tracing only. */
pxNewTCB->uxTCBNumber = uxTaskNumber;
+ vListInsertEnd(&xFullTaskList, &pxNewTCB->xFullListItem);
uxTaskNumber++;
@@ -1852,6 +1860,13 @@ static void prvInitialiseTCBVariables( t
pxTCB->ulRunTimeCounter = 0UL;
+ vListInitialiseItem( &( pxTCB->xFullListItem ) );
+ listSET_LIST_ITEM_OWNER( &( pxTCB->xFullListItem ), pxTCB );
+ #endif
@@ -1880,6 +1895,12 @@ unsigned portBASE_TYPE uxPriority;
+ vListInitialise( ( xList * ) &xFullTaskList );
+ #endif
/* Start with pxDelayedTaskList using list1 and the pxOverflowDelayedTaskList
using list2. */
pxDelayedTaskList = &xDelayedTaskList1;
@@ -2222,6 +2243,29 @@ void vTaskExitCritical( void )
+#if ( configUSE_TRACE_FACILITY == 1 )
+xTaskHandle handle = NULL;
+tskTCB *pxNextTCB=NULL, *pxFirstTCB=NULL;
+ portENTER_CRITICAL();
+ listGET_OWNER_OF_NEXT_ENTRY( pxFirstTCB, &xFullTaskList );
+ do
+ listGET_OWNER_OF_NEXT_ENTRY( pxNextTCB, &xFullTaskList );
+ if ( pxNextTCB->uxTCBNumber == uNumber ) {
+ handle = pxNextTCB;
+ break;
+ } while( pxNextTCB != pxFirstTCB );
+ portEXIT_CRITICAL();
+ return handle;
+#endif
</code></pre>
