Pilot thanks so much for the feedback! I’ve made some adjustments and hopeful improvements, but i’ll have to understand your interrupt/Timer better. I left the Serial.prints in there just for debugging but turn them off during a normal run, because yes, they do slow things down. The code below is getting me results down to 2000 uSec (about 500 Hz) without it repeating values but i’m still seeing jumps of 10000 uSec here and there. I think if i could take advantage of ESP32 mutliple SPIs would be better now that i’m using SPI for everything (instead of I2C).
Typical result (notice jump around 262000 uSec):
249854,-1.1495,-0.1149
251853,-1.3794,-0.1149
253853,-1.0345,-0.1149
255853,-1.2644,-0.1149
257853,-1.3794,-0.2299
259853,-1.2644,-0.2299
261853,-1.2644,-0.3448
270196,-1.2644,-0.3448
272853,-1.2644,-0.1149
274853,-1.1495,-0.2299
276853,-1.1495,-0.1149
278853,-0.8046,0.0000
280854,-1.2644,-0.2299
[Code] // Data logger: For measuring acceleration from LIS3DH
// Hardware: Adafruit ESP32, Adalogger feather+RTC, 1x LIS3DH accels (Currently, 2x in future)
// Created: May 12 2020
// Updated:
// Uses SPI for SD, I2C for Accels, hoping for 1000 Hz. sampling
// files are saves text files, csv = NNNNNNNN.TXT
// See ReadME and photos for additional hook up info
//Use ESP32 duo core
const int TaskCore1 = 1;
const int TaskCore0 = 0;
//Libraries
#include <Wire.h>
#include <SPI.h>
#include “SdFat.h”
#include <Adafruit_LIS3DH.h>
#include <Adafruit_Sensor.h>
#include “stdio.h”
#include “esp_system.h” //This inclusion configures the peripherals in the ESP system.
//#include “freertos/Arduino_FreeRTOS.h”
#include “freertos/FreeRTOS.h”
#include “freertos/task.h”
#include “freertos/timers.h”
#include “freertos/event_groups.h”
#include “freertos/queue.h”
//#include “freertos/stream_buffer.h”
// SD file definitions
const uint8_t sdChipSelect = 33;
SdFat sd;
SdFile file;
File logfile;
// Queue definitions
// data type for Queue item
struct Data_t {
uint32_t usec;
//float value1X;
float value1Y;
//float value1Z;
//float value2X;
float value2Y;
//float value2Z;
} xData_t;
//Declare Queue data type for FreeRTOS
QueueHandle_t DataQueue = NULL;
// interval between points in units of 1000 usec
const uint16_t intervalTicks = 2;
// Accel Lis3dh definitions, SPI or I2C
// Used for software SPI
//#define LIS3DH_CLK 32 //SCL
//#define LIS3DH_MISO 15 //SDO
//#define LIS3DH_MOSI 27 //SDA
// Used for hardware & software SPI
#define LIS3DH_CS 14 //ESP32: 14/A6 , Cortex m0: 5, Use for upper accel (Sensor 1!!!) = hbar, seatpost, etc.
#define LIS3DH_CS2 15 //ESP32: 15/A8, Cortex m0: 9, Use for lower accel (Sensor 2!!!) = axles, etc.
// software SPI
//Adafruit_LIS3DH lis = Adafruit_LIS3DH(LIS3DH_CS, LIS3DH_MOSI, LIS3DH_MISO, LIS3DH_CLK);
// hardware SPI 1 LIS3DH->Feather: Power to Vin, Gnd to Gnd, SCL->SCK, SDA->MOSO, SDO->MOSI, CS->CS 14/15
// Sensor 1 Hardware SPI
Adafruit_LIS3DH lis = Adafruit_LIS3DH(LIS3DH_CS);
// Sensor 2 Hardware SPI
Adafruit_LIS3DH lis2 = Adafruit_LIS3DH(LIS3DH_CS2);
// Sensor I2C
//Adafruit_LIS3DH lis = Adafruit_LIS3DH();
// define two tasks for Sensor Data and SD Write
void TaskGetData( void *pvParameters );
void TaskSDWrite( void *pvParameters );
void TaskSDFlush( void *pvParameters );
void TaskSDClose( void *pvParameters );
// Start the scheduler so the created tasks start executing. Need this for ESP32???
//void vTaskStartScheduler();
// the setup function runs once when you press reset or power the board
void setup() {
// initialize serial communication at 115200 bits per second:
Serial.begin(250000);
SPI.beginTransaction(SPISettings(40000000, MSBFIRST, SPI_MODE0));
//Outputs, Pins, Buttons, Etc.
pinMode(13, OUTPUT); //set Built in LED to show writing on SD Card
pinMode(4, INPUT); //button to turn recording on/off
//ACCEL Setup and RUN
if (! lis.begin(0x18)) { // change this to 0x19 for alternative i2c address
Serial.println(“Couldnt start”);
while (1) yield();
Serial.println(“LIS3DH Sensor 1 found!”);
if (! lis2.begin(0x19)) { // Sensor 2, SDO is 3V
Serial.println(“Couldnt start Sensor 2”);
while (1) yield();
Serial.println(“LIS3DH Sensor 2 found!”);
// Set accel range
lis.setRange(LIS3DH_RANGE_16_G); // 2, 4, 8 or 16 G!
lis2.setRange(LIS3DH_RANGE_16_G);
// Set DataRate
lis.setDataRate(LIS3DH_DATARATE_LOWPOWER_5KHZ); //OPTIONS: LIS3DH_DATARATE_400_HZ, LIS3DH_DATARATE_LOWPOWER_1K6HZ, LIS3DH_DATARATE_LOWPOWER_5KHZ
lis2.setDataRate(LIS3DH_DATARATE_LOWPOWER_5KHZ);
// SD CARD SETUP ====================================================================
// see if the card is present and can be initialized: (Use highest SD clock possible, but lower if has error, 15 Mhz works, possible to go to to 25 Mhz if sample rate is low enough
if (!sd.begin(sdChipSelect, SD_SCK_MHZ(15))) {
Serial.println(“Card init. failed!”);
//error(2);
// Create filename scheme ====================================================================
char filename[15];
// Setup filename to be appropriate for what you are testing
strcpy(filename, “/DATA00.TXT”);
for (uint8_t i = 0; i < 100; i++) {
filename[5] = ‘0’ + i/10;
filename[6] = ‘0’ + i%10;
// create if does not exist, do not open existing, write, sync after write
if (! sd.exists(filename)) {
break;
// Create file and prepare it ============================================================
logfile = sd.open(filename, O_CREAT | O_WRITE); //O_WRONLY | O_CREAT | O_EXCL ); // | O_TRUNC ));
if( ! logfile ) {
Serial.print("Couldnt create ");
Serial.println(filename);
//error(3);
Serial.print("Writing to ");
//Column labels
logfile.print(“Time”);
logfile.print(",");
logfile.print(“Sensor 1 X”);
logfile.print(",");
logfile.print(“Sensor 1 Y”);
logfile.print(",");
logfile.print(“Sensor 1 Z”);
logfile.print(",");
logfile.print(“Sensor 2 X”);
logfile.print(",");
logfile.print(“Sensor 2 Y”);
logfile.print(",");
logfile.print(“Sensor 2 Z”);
logfile.println();
//Queue Setup
DataQueue = xQueueCreate(10, sizeof( &xData_t ));
if(DataQueue == NULL){
Serial.println(“Error Creating the Queue”);
// Setup up Tasks and where to run ============================================================
// Now set up tasks to run independently.
xTaskCreatePinnedToCore(
TaskGetData
, “Get Data from Accel to Queue” // A name just for humans
, 10000 // This stack size can be checked & adjusted by reading the Stack Highwater
, NULL
, 4 // Priority, with 3 (configMAX_PRIORITIES - 1) being the highest, and 0 being the lowest.
, NULL
, TaskCore1);
TaskSDWrite
, “Get Data from Queue”
, 10000 // Stack size
, NULL
, 3 // Priority
, NULL
, TaskCore1);
TaskSDFlush
, “Write Data to Card”
, NULL
, 3 // Priority
, NULL
, TaskCore0);
TaskSDClose
, “Close the File”
, NULL
, 3 // Priority
, NULL
, TaskCore0);
void loop()
// Empty. Things are done in Tasks.
/---------------------- Tasks ---------------------/
void TaskGetData(void *pvParameters) // This is a task.
(void) pvParameters;
struct Data_t *pxPointerToxData_t;
for (;
// A Task shall never return or exit.
pxPointerToxData_t = &xData_t;
if(xQueueSend( DataQueue, (void *) &pxPointerToxData_t, 12 ) != pdPASS ) //portMAX_DELAY
//Serial.println("xQueueSend is not working");
sensors_event_t event;
lis.getEvent(&event);
sensors_event_t event2;
lis2.getEvent(&event2);
pxPointerToxData_t->usec = micros();
pxPointerToxData_t->value1X = event.acceleration.x;
pxPointerToxData_t->value1Y = event.acceleration.y;
pxPointerToxData_t->value1Z = event.acceleration.z;
pxPointerToxData_t->value2X = event2.acceleration.x;
pxPointerToxData_t->value2Y = event2.acceleration.y;
pxPointerToxData_t->value2Z = event2.acceleration.z;
/*Serial.print(pxPointerToxData_t->usec);
Serial.print(',');
Serial.print(pxPointerToxData_t->valueX,5);
Serial.print(',');
Serial.print(pxPointerToxData_t->valueY,5);
Serial.print(',');
Serial.print(pxPointerToxData_t->valueZ,5);
Serial.println();*/
//digitalWrite(LED_BUILTIN, HIGH); // turn the LED on (HIGH is the voltage level)
//vTaskDelay(100); // one tick delay (15ms) in between reads for stability
//digitalWrite(LED_BUILTIN, LOW); // turn the LED off by making the voltage LOW
vTaskDelay(intervalTicks); // one tick delay (1000 uSec/1 mSec) in between reads for 1000 Hz reading
vTaskDelete( NULL );
void TaskSDWrite(void *pvParameters) // This is a task.
struct Data_t xData_RCV, *pxData_RCV;
for (;
if(DataQueue != NULL )
if( xQueueReceive( DataQueue, &( pxData_RCV ), 12 ) != pdPASS ) //portMAX_DELAY
//Serial.println("xQueueRecieve is not working");
// print interval between points
/*if (last) {
logfile.print(p->usec - last);
} else {
logfile.write("NA");
last = p->usec;*/
//for (int i = 0; i <= 5000; i++) {
logfile.print(pxData_RCV->usec);
logfile.print(',');
logfile.print(pxData_RCV->value1X,4);
logfile.print(',');
logfile.print(pxData_RCV->value1Y,4);
logfile.print(',');
logfile.print(pxData_RCV->value1Z,4);
logfile.print(',');
logfile.print(pxData_RCV->value2X,4);
logfile.print(',');
logfile.print(pxData_RCV->value2Y,4);
logfile.print(',');
logfile.print(pxData_RCV->value2Z,4);
logfile.println();
/*Serial.print(pxData_RCV->usec);
Serial.print(',');
Serial.print(pxData_RCV->valueX,5);
Serial.print(',');
Serial.print(pxData_RCV->valueY,5);
Serial.print(',');
Serial.print(pxData_RCV->valueZ,5);
Serial.println(); */
//logfile.flush();
//uint16_t FreeSpace = uxQueueSpacesAvailable( DataQueue );
//Serial.println(FreeSpace);
//logfile.close();
void TaskSDFlush(void *pvParameters) // This is a task.
for (;
vTaskDelay( 500 );
logfile.flush();
//Serial.println(“Flushed file”);
vTaskDelete ( NULL );
void TaskSDClose(void *pvParameters) // This is a task.
for (;
vTaskDelay( 5000 );
logfile.close();
//Serial.println(“Close file”);
}[/Code]
