jarielmar wrote on Thursday, February 12, 2009:
I want to use trace macros.
In my FreeRTOSConfig file the maro configUSE_TRACE_FACILITY is = 1.
Then I have the following task:
static void vPeriodicTask( void *pvParameters )
vTaskSetApplicationTaskTag(NULL, (void *)1);
for( ;; )
vTaskDelay(5);
mPORTAToggleBits(BIT_0);
IFS0bits.CS1IF = 1;
but when I try to compile it the following error appear:
Executing: "C:\Archivos de programa\Microchip\MPLAB C32\bin\pic32-gcc.exe" -mprocessor=32MX460F512L -x c -c "main.c" -o"main.o" -MMD -MF"main.d" -I"D:\Proyectos\Panel\Software\Programa5" -g -DMPLAB_PIC32MX_PORT -Wall -fomit-frame-pointer
Executing: “C:\Archivos de programa\Microchip\MPLAB C32\bin\pic32-gcc.exe” -mprocessor=32MX460F512L -x c -c “tasks.c” -o"tasks.o" -MMD -MF"tasks.d" -I"D:\Proyectos\Panel\Software\Programa5" -g -DMPLAB_PIC32MX_PORT -Wall -fomit-frame-pointer
tasks.c:1837: warning: ‘prvListTaskWithinSingleList’ defined but not used
Executing: "C:\Archivos de programa\Microchip\MPLAB C32\bin\pic32-gcc.exe" -mprocessor=32MX460F512L -c -MMD -MF"port_asm.d" -I"D:\Proyectos\Panel\Software\Programa5" "port_asm.S" -o"port_asm.o" -I"D:\Proyectos\Panel\Software\Programa5" -I"." -Wa,–keep-locals,–gdwarf-2
Executing: "C:\Archivos de programa\Microchip\MPLAB C32\bin\pic32-gcc.exe" -mprocessor=32MX460F512L -x c -c "heap_2.c" -o"heap_2.o" -MMD -MF"heap_2.d" -I"D:\Proyectos\Panel\Software\Programa5" -g -DMPLAB_PIC32MX_PORT -Wall -fomit-frame-pointer
Executing: "C:\Archivos de programa\Microchip\MPLAB C32\bin\pic32-gcc.exe" -mprocessor=32MX460F512L -x c -c "list.c" -o"list.o" -MMD -MF"list.d" -I"D:\Proyectos\Panel\Software\Programa5" -g -DMPLAB_PIC32MX_PORT -Wall -fomit-frame-pointer
Executing: "C:\Archivos de programa\Microchip\MPLAB C32\bin\pic32-gcc.exe" -mprocessor=32MX460F512L -x c -c "port.c" -o"port.o" -MMD -MF"port.d" -I"D:\Proyectos\Panel\Software\Programa5" -g -DMPLAB_PIC32MX_PORT -Wall -fomit-frame-pointer
Executing: "C:\Archivos de programa\Microchip\MPLAB C32\bin\pic32-gcc.exe" -mprocessor=32MX460F512L -x c -c "croutine.c" -o"croutine.o" -MMD -MF"croutine.d" -I"D:\Proyectos\Panel\Software\Programa5" -g -DMPLAB_PIC32MX_PORT -Wall -fomit-frame-pointer
Executing: "C:\Archivos de programa\Microchip\MPLAB C32\bin\pic32-gcc.exe" -mprocessor=32MX460F512L -x c -c "queue.c" -o"queue.o" -MMD -MF"queue.d" -I"D:\Proyectos\Panel\Software\Programa5" -g -DMPLAB_PIC32MX_PORT -Wall -fomit-frame-pointer
Executing: "C:\Archivos de programa\Microchip\MPLAB C32\bin\pic32-gcc.exe" -mprocessor=32MX460F512L "main.o" "tasks.o" "port_asm.o" "heap_2.o" "list.o" "port.o" "croutine.o" "queue.o" -o"Programa5.elf" -Wl,–defsym=__MPLAB_BUILD=1,–defsym=_min_heap_size=0,-Map="Programa5.map"
main.o: In function `vPeriodicTask’:
D:\Proyectos\Panel\Software\Programa5/main.c:46: undefined reference to `vTaskSetApplicationTaskTag’
D:\Proyectos\Panel\Software\Programa5/main.c:46: relocation truncated to fit: R_MIPS_26 against `vTaskSetApplicationTaskTag’
Link step failed.
Release build of project `D:\Proyectos\Panel\Software\Programa5\Programa5.mcp’ failed.
Thu Feb 12 18:28:40 2009
BUILD FAILED
I have the task.c and task.h file in the project.
What is wrong?. Thank you in avanced.
