Hi folks:
I wonder why the prvAddNewTaskToReadyList only changed the pxCurrentTCB when a new task of equal or larger priority is added to ready list. I think we should also set xYieldPending to pdTRUE but why not? If we do not set xYieldPending , the pxCurrentTCB will not point to the correct task for a while until the next context switch occurs.
static void prvAddNewTaskToReadyList( TCB_t * pxNewTCB )
/* Ensure interrupts don't access the task lists while the lists are being
* updated. */
taskENTER_CRITICAL();
uxCurrentNumberOfTasks++;
if( pxCurrentTCB == NULL )
/* There are no other tasks, or all the other tasks are in
* the suspended state - make this the current task. */
pxCurrentTCB = pxNewTCB;
if( uxCurrentNumberOfTasks == ( UBaseType_t ) 1 )
/* This is the first task to be created so do the preliminary
* initialisation required. We will not recover if this call
* fails, but we will report the failure. */
prvInitialiseTaskLists();
mtCOVERAGE_TEST_MARKER();
/* If the scheduler is not already running, make this task the
* current task if it is the highest priority task to be created
* so far. */
if( xSchedulerRunning == pdFALSE )
if( pxCurrentTCB->uxPriority <= pxNewTCB->uxPriority )
uxTaskNumber++;
#if ( configUSE_TRACE_FACILITY == 1 )
/* Add a counter into the TCB for tracing only. */
pxNewTCB->uxTCBNumber = uxTaskNumber;
#endif /* configUSE_TRACE_FACILITY */
traceTASK_CREATE( pxNewTCB );
prvAddTaskToReadyList( pxNewTCB );
portSETUP_TCB( pxNewTCB );
taskEXIT_CRITICAL();
if( xSchedulerRunning != pdFALSE )
/* If the created task is of a higher priority than the current task
* then it should run now. */
if( pxCurrentTCB->uxPriority < pxNewTCB->uxPriority )
taskYIELD_IF_USING_PREEMPTION();
