I’m using the WIN32 simulator for study and understand FreeRTOS. I wanted to experiment with a small portTickType in order to generate a TickCount overflow and I’ve found that this line is diferent (and possible wrong) compared with other ports.
I found the same code diferent at the GCC MCF5235 port.
I think that the WIN32 simulator is a great tool for the FreeRTOS study and algorithm tests.
Without the parenthesis and if the portTickType is defined as unsigned portSHORT an overflow occurs within the portMS_TO_TICKS macro with values of ms greater than 57.
