I observed sporadic TCP payload corruption on a Zynq-7000 XC7Z020 running FreeRTOS and lwIP 2.2.0 with a hard-float build. The application source buffer was always correct, but in reproduced failures the data was already corrupted immediately after the normal lwIP memcpy into the TCP pbuf.
I use Vivado/Vitis 2025.2.
The linked memcpy uses VFP registers. I found that configUSE_TASK_FPU_SUPPORT was set to 0x1 and that the BSP provided a strong vApplicationIRQHandler(), which bypassed the FreeRTOS FPU-safe IRQ wrapper. To fix this, I changed the FreeRTOS BSP setting to FPU_SUPPORT = 0x2 and modified portZynq7000.c by renaming the BSP dispatcher from vApplicationIRQHandler() to vApplicationFPUSafeIRQHandler().
The final ELF then uses the FreeRTOS IRQ wrapper and saves/restores FPSCR and d0-d31 around interrupt dispatch. With the original optimized memcpy and D-cache enabled, 100,000 Ethernet datasets completed without corruption.
Could you confirm whether both changes are actually required for a hard-float Zynq-7000 FreeRTOS application? In particular, is modifying portZynq7000.c the intended solution, or is there an AMD-supported BSP setting or newer implementation that avoids changing the generated FreeRTOS port source
