The Cadence XTOS APIs change over time. I believe that is the root cause for the following.
In the Xtensa file “portasm.S” there is a routine
_frxt_tick_timer_init:
that uses the XTOS API
xtos_ints_on
Unfortunately, this API does not work with the API xtos_interrupt_enable. An application that calls xtos_interrupt_enable will, inadvertently, disable the tick timer interrupt. A solution that works for us to to change the code as follows
diff --git a/FreeRTOS/V10.4.6/portable/portasm.S b/FreeRTOS/V10.4.6/portable/portasm.S
index 06a657a..fd269a2 100644
--- a/FreeRTOS/V10.4.6/portable/portasm.S
+++ b/FreeRTOS/V10.4.6/portable/portasm.S
@@ -324,11 +324,11 @@ _frxt_tick_timer_init:
to the INTENABLE register because it may be virtualized.
#ifdef __XTENSA_CALL0_ABI__
- movi a2, XT_TIMER_INTEN
- call0 xt_ints_on
+ movi a2, XT_TIMER_INDEX
+ call0 xtos_interrupt_enable
#else
- movi a6, XT_TIMER_INTEN
- call4 xt_ints_on
+ movi a6, XT_TIMER_INDEX
+ call4 xtos_interrupt_enable
RET(16)
To go along with this the header file also needs to change
diff --git a/FreeRTOS/V10.4.6/portable/xtensa_api.h b/FreeRTOS/V10.4.6/portable/xtensa_api.h
index e124102…08817cb 100644
— a/FreeRTOS/V10.4.6/portable/xtensa_api.h
+++ b/FreeRTOS/V10.4.6/portable/xtensa_api.h
@@ -86,7 +86,7 @@ extern xt_handler xt_set_interrupt_handler(int n, xt_handler f, void * arg);
Returns the previous state of the interrupt enables.
-extern unsigned int xt_ints_on(unsigned int mask);
+extern unsigned int xtos_interrupt_enable(unsigned int mask);
