I think we have a winner here. Going on 2 hours of run time, I’ll check back in the AM
Nice one @jefftenney - I looked and didn’t even notice that.
@blondguy - please let me know if configLIBRARY_LOWEST_INTERRUPT_PRIORITY was something you set manually, or if it was set automatically by the tools. Thanks.
We do indeed have a winner. Thank you Jeff & Richard, the level of support you gave me surpassed what I expected. It gives me confidence in my choice of FreeRTOS!
As to your last question Richard, I think that value came from an example blinky project from NXP that an intern used for the initial creation of this code.
Once again, thank you both!
Question: Is there a reason to even offer this configuration if should always be based off of configPRIO_BITS?
Seems to me that both configLIBRARY_LOWEST_INTERRUPT_PRIORITY
and configPRIO_BITS
are useful symbols, and FreeRTOSConfig.h is a good home for them. That leaves the application developer responsible for making sure they agree with each other, with help from sample applications and/or tool-generated projects.
However, configKERNEL_INTERRUPT_PRIORITY
(another symbol from FreeRTOSConfig.h) should maybe not control the PendSV priority after all. It should probably control the Systick priority only.
