ardroliat wrote on Tuesday, May 08, 2012:
Hi
I have an existing windows console application that has printf() and I can use redirection using >SomeFilename to capture the output.
I have got the same application now working on top of the FreeRTOS Win32 simulation port.
Running the resulting application produces the same output to the console.
However if I then append >Somefilename when I launch the app, I end up with an empty ‘Somefilename’.
I am puzzled as to why console redirection to a file is not working.
I am using the source code from V7.1.0
If it is relevant, my applcation is built using Visual Studion 2008 and not 2010 as in the demo app in 7.1.0
Is there a special library I need to invoke?
I thank you in advance
Kind regards
Ard
