vTaskStepTick is randomly Asserting
mrazoun wrote on Friday, June 16, 2017:
Hi Nelson,
try to use it also for RTC. The main problem is that you have to read running timer, because if you will stop it will be cleared. And that behaviour is the same for RTC and BURTC, as I red in datasheet. Rest of it is described in my first post.
Mayby anybody from FreeRTOS developers can look on it, I think some fix can be done.
I applied described fix into my code and the bug seems to be fixed after long time testing.
Zdenek
I see many posts about this issue including one confirming that there is a bug 3 month ago by Susheel Nuguru. Unfortunately as a new user I cannot put a link to that thread.
Do you have a patch or fix? I am experiencing it too.
I think the code that is causing the assertion failure comes from your MCU vendor – Nordic or Silicon Labs etc. You may have better luck checking with them or one of their forums.
Which hardware platform are you using? Can you link the issue you mentioned?
@aggarg Here’s the one I found https://devzone.nordicsemi.com/f/nordic-q-a/67434/assert-in-freertos-task-c-configassert-xtickcount-xtickstojump-xnexttaskunblocktime.
Thanks Jeff. Yes, you are right - this one seems to be an issue in their implementation of vPortSuppressTicksAndSleep. @yshteinm Did you try the work-around suggested there?
Thank you @jefftenney That’s the one.
Hi @aggarg ,
I am using Ambiq Apollo3, so it is not CPU specific. I tried to increase configEXPECTED_IDLE_TIME_BEFORE_SLEEP to 3. Testing it now. As it doesn’t happen constantly not sure yet how it will work for me. Any idea when they are going to fix it?
@system
Hi Yuri,
Can you confirm you are using a “third-party” version of vPortSuppressTicksAndSleep()? The “official” version of vPortSuppressTicksAndSleep() is in port.c, provided by FreeRTOS, but it is defined weakly, which allows you to replace it with something you write yourself or with something provided by a third party. Can you tell where your version of vPortSuppressTicksAndSleep() came from?
Hi @jefftenney ,
It probably came from Ambiq. Is there corrected version of vPortSuppressTicksAndSleep from FreeRTOS? I could modify the code then.
You’ll need to work with Ambiq to get them to fix their code.
Or you could switch to use the official freertos code, but you may lose some of the low power features in Ambiq’s version.
@jefftenney
Is it fixed in official freertos code? What version should I use?
Following this thread it is not clear to me if you are using code from us or not. Can you please post or otherwise link to the port.c file you are using.
 * FreeRTOS Kernel V10.1.1
 * Copyright (C) 2018 Amazon.com, Inc. or its affiliates.  All Rights Reserved.
 * Permission is hereby granted, free of charge, to any person obtaining a copy of
 * this software and associated documentation files (the "Software"), to deal in
 * the Software without restriction, including without limitation the rights to
 * use, copy, modify, merge, publish, distribute, sublicense, and/or sell copies of
 * the Software, and to permit persons to whom the Software is furnished to do so,
 * subject to the following conditions:
 * The above copyright notice and this permission notice shall be included in all
 * copies or substantial portions of the Software.
 * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
 * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS
 * FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR
 * COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER
 * IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN
 * CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
 * http://www.FreeRTOS.org
 * http://aws.amazon.com/freertos
 * 1 tab == 4 spaces!
 * Implementation of functions defined in portable.h for the ARM CM4F port.
/* IAR includes. */
#include <intrinsics.h>
/* Scheduler includes. */
#include "FreeRTOS.h"
#include "task.h"
/* hardware includes */
#include "am_mcu_apollo.h"
#include "am_bsp.h"
// A Possible clock glitch could rarely cause the Stimer interrupt to be lost.
// Set up a backup comparator to handle this case
#define AM_FREERTOS_STIMER_BACKUP
//#define FREERTOS_STIMER_DIAGS
#ifdef AM_FREERTOS_STIMER_DIAGS
uint32_t gF_stimerHistory[256][4];
uint8_t gF_stimerHistoryCount = 0;
uint32_t gF_stimerGetHistory[256][4];
uint8_t gF_stimerGetHistoryCount = 0;
// Check to make sure the FreeRTOSConfig.h options are consistent per the implementation
#if configOVERRIDE_DEFAULT_TICK_CONFIGURATION == 1
#if configUSE_TICKLESS_IDLE != 2
#error "configOVERRIDE_DEFAULT_TICK_CONFIGURATION == 1 supported only for configUSE_TICKLESS_IDLE = 2"
#ifndef AM_FREERTOS_USE_STIMER_FOR_TICK
// Determine which CTimer to use if configured to use CTimer for FreeRTOS Tick
#ifndef configCTIMER_NUM
// Default
#define configCTIMER_NUM 	1
#ifdef AM_PART_APOLLO
#if configCTIMER_NUM == 0
#error "Apollo can not use CTimer0 in 32b mode"
#define AM_FREERTOS_CTIMER_INT 	AM_HAL_CTIMER_INT_TIMERA0
#elif configCTIMER_NUM == 1
#define AM_FREERTOS_CTIMER_INT 	AM_HAL_CTIMER_INT_TIMERA1
#elif configCTIMER_NUM == 2
#define AM_FREERTOS_CTIMER_INT 	AM_HAL_CTIMER_INT_TIMERA2
#elif configCTIMER_NUM == 3
#define AM_FREERTOS_CTIMER_INT 	AM_HAL_CTIMER_INT_TIMERA3
#ifndef configCTIMER_CLOCK_HZ
// Default
#define configCTIMER_CLOCK_HZ   32768
#define configCTIMER_CLOCK      AM_HAL_CTIMER_XT_32_768KHZ
#else
#if configCTIMER_CLOCK_HZ == 32768
// Default - for backward compatibility
#else
#error "configCTIMER_CLOCK not specified"
#else
#error "Apollo can not use STimer for FreeRTOS"
#ifndef configSTIMER_CLOCK_HZ
// Default
#define configSTIMER_CLOCK_HZ   32768
#define configSTIMER_CLOCK      AM_HAL_STIMER_XTAL_32KHZ
#else
#if configSTIMER_CLOCK_HZ == 32768
#else
#error "configSTIMER_CLOCK not specified"
// Keeps the snapshot of the STimer corresponding to last tick update
static uint32_t g_lastSTimerVal = 0;
/* The Ctimer is a 16-bit counter.  */
#define portMAX_16_BIT_NUMBER		( 0x0000ffffUL )
/* The Stimer is a 32-bit counter. */
#define portMAX_32_BIT_NUMBER		( 0xffffffffUL )
#if configOVERRIDE_DEFAULT_TICK_CONFIGURATION == 0
#if configUSE_TICKLESS_IDLE == 2
// This implementation is TODO - will use Systick when active, but fall back to STimer/Ctimer when Idle
// Some crude analysis showed that doing so is no better than using CTImer/STimer always, in terms of power
// Hence there is no plan currently to implement it.
#error "configOVERRIDE_DEFAULT_TICK_CONFIGURATION == 0 not supported for configUSE_TICKLESS_IDLE = 2"
#ifndef __ARMVFP__
	#error This port can only be used when the project options are configured to enable hardware floating point support.
#if( configMAX_SYSCALL_INTERRUPT_PRIORITY == 0 )
	#error configMAX_SYSCALL_INTERRUPT_PRIORITY must not be set to 0.  See http://www.FreeRTOS.org/RTOS-Cortex-M3-M4.html
#ifndef configSYSTICK_CLOCK_HZ
	#define configSYSTICK_CLOCK_HZ configCPU_CLOCK_HZ
	/* Ensure the SysTick is clocked at the same frequency as the core. */
	#define portNVIC_SYSTICK_CLK_BIT	( 1UL << 2UL )
#else
	/* The way the SysTick is clocked is not modified in case it is not the same
	as the core. */
	#define portNVIC_SYSTICK_CLK_BIT	( 0 )
/* Constants required to manipulate the core.  Registers first... */
#define portNVIC_SYSTICK_CTRL_REG			( * ( ( volatile uint32_t * ) 0xe000e010 ) )
#define portNVIC_SYSTICK_LOAD_REG			( * ( ( volatile uint32_t * ) 0xe000e014 ) )
#define portNVIC_SYSTICK_CURRENT_VALUE_REG	( * ( ( volatile uint32_t * ) 0xe000e018 ) )
#define portNVIC_SYSPRI2_REG				( * ( ( volatile uint32_t * ) 0xe000ed20 ) )
/* ...then bits in the registers. */
#define portNVIC_SYSTICK_INT_BIT			( 1UL << 1UL )
#define portNVIC_SYSTICK_ENABLE_BIT			( 1UL << 0UL )
#define portNVIC_SYSTICK_COUNT_FLAG_BIT		( 1UL << 16UL )
#define portNVIC_PENDSVCLEAR_BIT 			( 1UL << 27UL )
#define portNVIC_PEND_SYSTICK_CLEAR_BIT		( 1UL << 25UL )
/* Constants used to detect a Cortex-M7 r0p1 core, which should use the ARM_CM7
r0p1 port. */
#define portCPUID							( * ( ( volatile uint32_t * ) 0xE000ed00 ) )
#define portCORTEX_M7_r0p1_ID				( 0x410FC271UL )
#define portCORTEX_M7_r0p0_ID				( 0x410FC270UL )
#define portNVIC_PENDSV_PRI					( ( ( uint32_t ) configKERNEL_INTERRUPT_PRIORITY ) << 16UL )
#define portNVIC_SYSTICK_PRI				( ( ( uint32_t ) configKERNEL_INTERRUPT_PRIORITY ) << 24UL )
/* Constants required to check the validity of an interrupt priority. */
#define portFIRST_USER_INTERRUPT_NUMBER		( 16 )
#define portNVIC_IP_REGISTERS_OFFSET_16 	( 0xE000E3F0 )
#define portAIRCR_REG						( * ( ( volatile uint32_t * ) 0xE000ED0C ) )
#define portMAX_8_BIT_VALUE					( ( uint8_t ) 0xff )
#define portTOP_BIT_OF_BYTE					( ( uint8_t ) 0x80 )
#define portMAX_PRIGROUP_BITS				( ( uint8_t ) 7 )
#define portPRIORITY_GROUP_MASK				( 0x07UL << 8UL )
#define portPRIGROUP_SHIFT					( 8UL )
/* Masks off all bits but the VECTACTIVE bits in the ICSR register. */
#define portVECTACTIVE_MASK					( 0xFFUL )
/* Constants required to manipulate the VFP. */
#define portFPCCR							( ( volatile uint32_t * ) 0xe000ef34 ) /* Floating point context control register. */
#define portASPEN_AND_LSPEN_BITS			( 0x3UL << 30UL )
/* Constants required to set up the initial stack. */
#define portINITIAL_XPSR					( 0x01000000 )
#define portINITIAL_EXC_RETURN				( 0xfffffffd )
/* The systick is a 24-bit counter. */
#define portMAX_24_BIT_NUMBER				( 0xffffffUL )
/* A fiddle factor to estimate the number of SysTick counts that would have
occurred while the SysTick counter is stopped during tickless idle
calculations. */
#define portMISSED_COUNTS_FACTOR			( 45UL )
/* For strict compliance with the Cortex-M spec the task start address should
have bit-0 clear, as it is loaded into the PC on exit from an ISR. */
#define portSTART_ADDRESS_MASK				( ( StackType_t ) 0xfffffffeUL )
 * Setup the timer to generate the tick interrupts.  The implementation in this
 * file is weak to allow application writers to change the timer used to
 * generate the tick interrupt.
void vPortSetupTimerInterrupt( void );
 * Exception handlers.
void xPortSysTickHandler( void );
 * Start first task is a separate function so it can be tested in isolation.
extern void vPortStartFirstTask( void );
 * Turn the VFP on.
extern void vPortEnableVFP( void );
 * Used to catch tasks that attempt to return from their implementing function.
static void prvTaskExitError( void );
/* Each task maintains its own interrupt status in the critical nesting
variable. */
static UBaseType_t uxCriticalNesting = 0xaaaaaaaa;
 * The number of SysTick increments that make up one tick period.
#if( configUSE_TICKLESS_IDLE == 1 )
	static uint32_t ulTimerCountsForOneTick = 0;
#endif /* configUSE_TICKLESS_IDLE */
 * The maximum number of tick periods that can be suppressed is limited by the
 * 24 bit resolution of the SysTick timer.
	static uint32_t xMaximumPossibleSuppressedTicks = 0;
 * Compensate for the CPU cycles that pass while the SysTick is stopped (low
 * power functionality only.
	static uint32_t ulStoppedTimerCompensation = 0;
 * Used by the portASSERT_IF_INTERRUPT_PRIORITY_INVALID() macro to ensure
 * FreeRTOS API functions are not called from interrupts that have been assigned
 * a priority above configMAX_SYSCALL_INTERRUPT_PRIORITY.
#if( configASSERT_DEFINED == 1 )
	 static uint8_t ucMaxSysCallPriority = 0;
	 static uint32_t ulMaxPRIGROUPValue = 0;
	 static const volatile uint8_t * const pcInterruptPriorityRegisters = ( const volatile uint8_t * const ) portNVIC_IP_REGISTERS_OFFSET_16;
#endif /* configASSERT_DEFINED */
 * See header file for description.
StackType_t *pxPortInitialiseStack( StackType_t *pxTopOfStack, TaskFunction_t pxCode, void *pvParameters )
	/* Simulate the stack frame as it would be created by a context switch
	interrupt. */
	/* Offset added to account for the way the MCU uses the stack on entry/exit
	of interrupts, and to ensure alignment. */
	pxTopOfStack--;
	*pxTopOfStack = portINITIAL_XPSR;	/* xPSR */
	pxTopOfStack--;
	*pxTopOfStack = ( ( StackType_t ) pxCode ) & portSTART_ADDRESS_MASK;	/* PC */
	pxTopOfStack--;
	*pxTopOfStack = ( StackType_t ) prvTaskExitError;	/* LR */
	/* Save code space by skipping register initialisation. */
	pxTopOfStack -= 5;	/* R12, R3, R2 and R1. */
	*pxTopOfStack = ( StackType_t ) pvParameters;	/* R0 */
	/* A save method is being used that requires each task to maintain its
	own exec return value. */
	pxTopOfStack--;
	*pxTopOfStack = portINITIAL_EXC_RETURN;
	pxTopOfStack -= 8;	/* R11, R10, R9, R8, R7, R6, R5 and R4. */
	return pxTopOfStack;
	/* A function that implements a task must not exit or attempt to return to
	its caller as there is nothing to return to.  If a task wants to exit it
	should instead call vTaskDelete( NULL ).
	Artificially force an assert() to be triggered if configASSERT() is
	defined, then stop here so application writers can catch the error. */
	configASSERT( uxCriticalNesting == ~0UL );
	portDISABLE_INTERRUPTS();
	for( ;; );
BaseType_t xPortStartScheduler( void )
	/* configMAX_SYSCALL_INTERRUPT_PRIORITY must not be set to 0.
	See http://www.FreeRTOS.org/RTOS-Cortex-M3-M4.html */
	configASSERT( configMAX_SYSCALL_INTERRUPT_PRIORITY );
	/* This port can be used on all revisions of the Cortex-M7 core other than
	the r0p1 parts.  r0p1 parts should use the port from the
	/source/portable/GCC/ARM_CM7/r0p1 directory. */
	configASSERT( portCPUID != portCORTEX_M7_r0p1_ID );
	configASSERT( portCPUID != portCORTEX_M7_r0p0_ID );
		volatile uint32_t ulOriginalPriority;
		volatile uint8_t * const pucFirstUserPriorityRegister = ( volatile uint8_t * const ) ( portNVIC_IP_REGISTERS_OFFSET_16 + portFIRST_USER_INTERRUPT_NUMBER );
		volatile uint8_t ucMaxPriorityValue;
		/* Determine the maximum priority from which ISR safe FreeRTOS API
		functions can be called.  ISR safe functions are those that end in
		"FromISR".  FreeRTOS maintains separate thread and ISR API functions to
		ensure interrupt entry is as fast and simple as possible.
		Save the interrupt priority value that is about to be clobbered. */
		ulOriginalPriority = *pucFirstUserPriorityRegister;
		/* Determine the number of priority bits available.  First write to all
		possible bits. */
		*pucFirstUserPriorityRegister = portMAX_8_BIT_VALUE;
		/* Read the value back to see how many bits stuck. */
		ucMaxPriorityValue = *pucFirstUserPriorityRegister;
		/* Use the same mask on the maximum system call priority. */
		ucMaxSysCallPriority = configMAX_SYSCALL_INTERRUPT_PRIORITY & ucMaxPriorityValue;
		/* Calculate the maximum acceptable priority group value for the number
		of bits read back. */
		ulMaxPRIGROUPValue = portMAX_PRIGROUP_BITS;
		while( ( ucMaxPriorityValue & portTOP_BIT_OF_BYTE ) == portTOP_BIT_OF_BYTE )
			ulMaxPRIGROUPValue--;
			ucMaxPriorityValue <<= ( uint8_t ) 0x01;
		#ifdef __NVIC_PRIO_BITS
			/* Check the CMSIS configuration that defines the number of
			priority bits matches the number of priority bits actually queried
			from the hardware. */
			configASSERT( ( portMAX_PRIGROUP_BITS - ulMaxPRIGROUPValue ) == __NVIC_PRIO_BITS );
		#ifdef configPRIO_BITS
			/* Check the FreeRTOS configuration that defines the number of
			configASSERT( ( portMAX_PRIGROUP_BITS - ulMaxPRIGROUPValue ) == configPRIO_BITS );
		/* Shift the priority group value back to its position within the AIRCR
		register. */
		ulMaxPRIGROUPValue <<= portPRIGROUP_SHIFT;
		ulMaxPRIGROUPValue &= portPRIORITY_GROUP_MASK;
		/* Restore the clobbered interrupt priority register to its original
		value. */
		*pucFirstUserPriorityRegister = ulOriginalPriority;
	#endif /* conifgASSERT_DEFINED */
	/* Make PendSV and SysTick the lowest priority interrupts. */
	portNVIC_SYSPRI2_REG |= portNVIC_PENDSV_PRI;
	portNVIC_SYSPRI2_REG |= portNVIC_SYSTICK_PRI;
	/* Start the timer that generates the tick ISR.  Interrupts are disabled
	here already. */
	vPortSetupTimerInterrupt();
	/* Initialise the critical nesting count ready for the first task. */
	uxCriticalNesting = 0;
	/* Ensure the VFP is enabled - it should be anyway. */
	vPortEnableVFP();
	/* Lazy save always. */
	*( portFPCCR ) |= portASPEN_AND_LSPEN_BITS;
	/* Start the first task. */
	vPortStartFirstTask();
	/* Should not get here! */
	return 0;
void vPortEndScheduler( void )
	/* Not implemented in ports where there is nothing to return to.
	Artificially force an assert. */
	configASSERT( uxCriticalNesting == 1000UL );
void vPortEnterCritical( void )
	uxCriticalNesting++;
	/* This is not the interrupt safe version of the enter critical function so
	assert() if it is being called from an interrupt context.  Only API
	functions that end in "FromISR" can be used in an interrupt.  Only assert if
	the critical nesting count is 1 to protect against recursive calls if the
	assert function also uses a critical section. */
	if( uxCriticalNesting == 1 )
		configASSERT( ( portNVIC_INT_CTRL_REG & portVECTACTIVE_MASK ) == 0 );
void vPortExitCritical( void )
	configASSERT( uxCriticalNesting );
	uxCriticalNesting--;
	if( uxCriticalNesting == 0 )
		portENABLE_INTERRUPTS();
	/* The SysTick runs at the lowest interrupt priority, so when this interrupt
	executes all interrupts must be unmasked.  There is therefore no need to
	save and then restore the interrupt mask value as its value is already
	known. */
		/* Increment the RTOS tick. */
		if( xTaskIncrementTick() != pdFALSE )
			/* A context switch is required.  Context switching is performed in
			the PendSV interrupt.  Pend the PendSV interrupt. */
			portNVIC_INT_CTRL_REG = portNVIC_PENDSVSET_BIT;
	__weak void vPortSuppressTicksAndSleep( TickType_t xExpectedIdleTime )
	uint32_t ulReloadValue, ulCompleteTickPeriods, ulCompletedSysTickDecrements;
	TickType_t xModifiableIdleTime;
		/* Make sure the SysTick reload value does not overflow the counter. */
		if( xExpectedIdleTime > xMaximumPossibleSuppressedTicks )
			xExpectedIdleTime = xMaximumPossibleSuppressedTicks;
		/* Stop the SysTick momentarily.  The time the SysTick is stopped for
		is accounted for as best it can be, but using the tickless mode will
		inevitably result in some tiny drift of the time maintained by the
		kernel with respect to calendar time. */
		portNVIC_SYSTICK_CTRL_REG &= ~portNVIC_SYSTICK_ENABLE_BIT;
		/* Calculate the reload value required to wait xExpectedIdleTime
		tick periods.  -1 is used because this code will execute part way
		through one of the tick periods. */
		ulReloadValue = portNVIC_SYSTICK_CURRENT_VALUE_REG + ( ulTimerCountsForOneTick * ( xExpectedIdleTime - 1UL ) );
		if( ulReloadValue > ulStoppedTimerCompensation )
			ulReloadValue -= ulStoppedTimerCompensation;
		/* Enter a critical section but don't use the taskENTER_CRITICAL()
		method as that will mask interrupts that should exit sleep mode. */
		__disable_interrupt();
		__DSB();
		__ISB();
		/* If a context switch is pending or a task is waiting for the scheduler
		to be unsuspended then abandon the low power entry. */
		if( eTaskConfirmSleepModeStatus() == eAbortSleep )
			/* Restart from whatever is left in the count register to complete
			this tick period. */
			portNVIC_SYSTICK_LOAD_REG = portNVIC_SYSTICK_CURRENT_VALUE_REG;
			/* Restart SysTick. */
			portNVIC_SYSTICK_CTRL_REG |= portNVIC_SYSTICK_ENABLE_BIT;
			/* Reset the reload register to the value required for normal tick
			periods. */
			portNVIC_SYSTICK_LOAD_REG = ulTimerCountsForOneTick - 1UL;
			/* Re-enable interrupts - see comments above __disable_interrupt()
			call above. */
			__enable_interrupt();
			/* Set the new reload value. */
			portNVIC_SYSTICK_LOAD_REG = ulReloadValue;
			/* Clear the SysTick count flag and set the count value back to
			zero. */
			portNVIC_SYSTICK_CURRENT_VALUE_REG = 0UL;
			/* Sleep until something happens.  configPRE_SLEEP_PROCESSING() can
			set its parameter to 0 to indicate that its implementation contains
			its own wait for interrupt or wait for event instruction, and so wfi
			should not be executed again.  However, the original expected idle
			time variable must remain unmodified, so a copy is taken. */
			xModifiableIdleTime = xExpectedIdleTime;
			configPRE_SLEEP_PROCESSING( xModifiableIdleTime );
			if( xModifiableIdleTime > 0 )
				__DSB();
				__WFI();
				__ISB();
			configPOST_SLEEP_PROCESSING( xExpectedIdleTime );
			/* Re-enable interrupts to allow the interrupt that brought the MCU
			out of sleep mode to execute immediately.  see comments above
			__disable_interrupt() call above. */
			__DSB();
			__ISB();
			/* Disable interrupts again because the clock is about to be stopped
			and interrupts that execute while the clock is stopped will increase
			any slippage between the time maintained by the RTOS and calendar
			time. */
			__DSB();
			__ISB();
			/* Disable the SysTick clock without reading the
			portNVIC_SYSTICK_CTRL_REG register to ensure the
			portNVIC_SYSTICK_COUNT_FLAG_BIT is not cleared if it is set.  Again,
			the time the SysTick is stopped for is accounted for as best it can
			be, but using the tickless mode will inevitably result in some tiny
			drift of the time maintained by the kernel with respect to calendar
			time*/
			portNVIC_SYSTICK_CTRL_REG = ( portNVIC_SYSTICK_CLK_BIT | portNVIC_SYSTICK_INT_BIT );
			/* Determine if the SysTick clock has already counted to zero and
			been set back to the current reload value (the reload back being
			correct for the entire expected idle time) or if the SysTick is yet
			to count to zero (in which case an interrupt other than the SysTick
			must have brought the system out of sleep mode). */
			if( ( portNVIC_SYSTICK_CTRL_REG & portNVIC_SYSTICK_COUNT_FLAG_BIT ) != 0 )
				uint32_t ulCalculatedLoadValue;
				/* The tick interrupt is already pending, and the SysTick count
				reloaded with ulReloadValue.  Reset the
				portNVIC_SYSTICK_LOAD_REG with whatever remains of this tick
				period. */
				ulCalculatedLoadValue = ( ulTimerCountsForOneTick - 1UL ) - ( ulReloadValue - portNVIC_SYSTICK_CURRENT_VALUE_REG );
				/* Don't allow a tiny value, or values that have somehow
				underflowed because the post sleep hook did something
				that took too long. */
				if( ( ulCalculatedLoadValue < ulStoppedTimerCompensation ) || ( ulCalculatedLoadValue > ulTimerCountsForOneTick ) )
					ulCalculatedLoadValue = ( ulTimerCountsForOneTick - 1UL );
				portNVIC_SYSTICK_LOAD_REG = ulCalculatedLoadValue;
				/* As the pending tick will be processed as soon as this
				function exits, the tick value maintained by the tick is stepped
				forward by one less than the time spent waiting. */
				ulCompleteTickPeriods = xExpectedIdleTime - 1UL;
				/* Something other than the tick interrupt ended the sleep.
				Work out how long the sleep lasted rounded to complete tick
				periods (not the ulReload value which accounted for part
				ticks). */
				ulCompletedSysTickDecrements = ( xExpectedIdleTime * ulTimerCountsForOneTick ) - portNVIC_SYSTICK_CURRENT_VALUE_REG;
				/* How many complete tick periods passed while the processor
				was waiting? */
				ulCompleteTickPeriods = ulCompletedSysTickDecrements / ulTimerCountsForOneTick;
				/* The reload value is set to whatever fraction of a single tick
				period remains. */
				portNVIC_SYSTICK_LOAD_REG = ( ( ulCompleteTickPeriods + 1UL ) * ulTimerCountsForOneTick ) - ulCompletedSysTickDecrements;
			/* Restart SysTick so it runs from portNVIC_SYSTICK_LOAD_REG
			again, then set portNVIC_SYSTICK_LOAD_REG back to its standard
			value. */
			vTaskStepTick( ulCompleteTickPeriods );
			/* Exit with interrpts enabled. */
 * Setup the systick timer to generate the tick interrupts at the required
 * frequency.
__weak void vPortSetupTimerInterrupt( void )
	/* Calculate the constants required to configure the tick interrupt. */
		ulTimerCountsForOneTick = ( configSYSTICK_CLOCK_HZ / configTICK_RATE_HZ );
		xMaximumPossibleSuppressedTicks = portMAX_24_BIT_NUMBER / ulTimerCountsForOneTick;
		ulStoppedTimerCompensation = portMISSED_COUNTS_FACTOR / ( configCPU_CLOCK_HZ / configSYSTICK_CLOCK_HZ );
	/* Stop and clear the SysTick. */
	portNVIC_SYSTICK_CTRL_REG = 0UL;
	/* Configure SysTick to interrupt at the requested rate. */
	portNVIC_SYSTICK_LOAD_REG = ( configSYSTICK_CLOCK_HZ / configTICK_RATE_HZ ) - 1UL;
	portNVIC_SYSTICK_CTRL_REG = ( portNVIC_SYSTICK_CLK_BIT | portNVIC_SYSTICK_INT_BIT | portNVIC_SYSTICK_ENABLE_BIT );
#endif /* configOVERRIDE_DEFAULT_TICK_CONFIGURATION */
	void vPortValidateInterruptPriority( void )
	uint32_t ulCurrentInterrupt;
	uint8_t ucCurrentPriority;
		/* Obtain the number of the currently executing interrupt. */
		__asm volatile( "mrs %0, ipsr" : "=r"( ulCurrentInterrupt ) :: "memory" );
		/* Is the interrupt number a user defined interrupt? */
		if( ulCurrentInterrupt >= portFIRST_USER_INTERRUPT_NUMBER )
			/* Look up the interrupt's priority. */
			ucCurrentPriority = pcInterruptPriorityRegisters[ ulCurrentInterrupt ];
			/* The following assertion will fail if a service routine (ISR) for
			an interrupt that has been assigned a priority above
			configMAX_SYSCALL_INTERRUPT_PRIORITY calls an ISR safe FreeRTOS API
			function.  ISR safe FreeRTOS API functions must *only* be called
			from interrupts that have been assigned a priority at or below
			Numerically low interrupt priority numbers represent logically high
			interrupt priorities, therefore the priority of the interrupt must
			be set to a value equal to or numerically *higher* than
			Interrupts that	use the FreeRTOS API must not be left at their
			default priority of	zero as that is the highest possible priority,
			which is guaranteed to be above configMAX_SYSCALL_INTERRUPT_PRIORITY,
			and	therefore also guaranteed to be invalid.
			FreeRTOS maintains separate thread and ISR API functions to ensure
			The following links provide detailed information:
			http://www.freertos.org/RTOS-Cortex-M3-M4.html
			http://www.freertos.org/FAQHelp.html */
			configASSERT( ucCurrentPriority >= ucMaxSysCallPriority );
		/* Priority grouping:  The interrupt controller (NVIC) allows the bits
		that define each interrupt's priority to be split between bits that
		define the interrupt's pre-emption priority bits and bits that define
		the interrupt's sub-priority.  For simplicity all bits must be defined
		to be pre-emption priority bits.  The following assertion will fail if
		this is not the case (if some bits represent a sub-priority).
		If the application only uses CMSIS libraries for interrupt
		configuration then the correct setting can be achieved on all Cortex-M
		devices by calling NVIC_SetPriorityGrouping( 0 ); before starting the
		scheduler.  Note however that some vendor specific peripheral libraries
		assume a non-zero priority group setting, in which cases using a value
		of zero will result in unpredictable behaviour. */
		configASSERT( ( portAIRCR_REG & portPRIORITY_GROUP_MASK ) <= ulMaxPRIGROUPValue );
#if configOVERRIDE_DEFAULT_TICK_CONFIGURATION != 0
 * Implementation of functions defined in portable.h for the Ambiq Apollo_2 port.
/* This port requires using the Stimer for Tickless_Idle in the Apollo_2 device  */      // dv**** 102616
 * resolution of the Tick timer.
	uint32_t ulReloadValue;
    uint32_t New_Timer, Delta_Sleep;
    uint32_t elapsed_time;
	ulReloadValue =  ulTimerCountsForOneTick * ( xExpectedIdleTime - 1 );
	__DSB();
	__ISB();
#ifdef AM_FREERTOS_USE_STIMER_FOR_TICK
    // Adjust for the time already elapsed
    uint32_t curTime = am_hal_stimer_counter_get();
    gF_stimerGetHistory[gF_stimerGetHistoryCount][0] = gF_stimerGetHistoryCount;
    gF_stimerGetHistory[gF_stimerGetHistoryCount][1] = curTime;
    gF_stimerGetHistory[gF_stimerGetHistoryCount][2] = AM_REGVAL(AM_REG_STIMER_COMPARE(0, 0));
    gF_stimerGetHistory[gF_stimerGetHistoryCount][3] = gF_stimerHistoryCount;
    gF_stimerGetHistoryCount++;
    elapsed_time = curTime - g_lastSTimerVal;
#else
    am_hal_ctimer_stop(configCTIMER_NUM, AM_HAL_CTIMER_BOTH);
    elapsed_time = am_hal_ctimer_read(configCTIMER_NUM, AM_HAL_CTIMER_BOTH);
    /* Abandon low power entry if the sleep time is too short */
	if( (eTaskConfirmSleepModeStatus() == eAbortSleep) || ((elapsed_time + ulTimerCountsForOneTick) > ulReloadValue) )
        am_hal_ctimer_start(configCTIMER_NUM, AM_HAL_CTIMER_BOTH);
		/* Re-enable interrupts - see comments above __disable_irq() call
		above. */
        ulReloadValue -= elapsed_time;
        // Initialize new timeout value
        am_hal_stimer_compare_delta_set(0, ulReloadValue);
#ifdef AM_FREERTOS_STIMER_BACKUP
        am_hal_stimer_compare_delta_set(1, ulReloadValue+1);
#else
        am_hal_ctimer_clear(configCTIMER_NUM, AM_HAL_CTIMER_BOTH);
        am_hal_ctimer_compare_set(configCTIMER_NUM, AM_HAL_CTIMER_BOTH, 0, ulReloadValue);
		configPRE_SLEEP_PROCESSING( xModifiableIdleTime );       // Turn OFF all Periphials in this function
				__DSB();
				__WFI();
				__ISB();
		configPOST_SLEEP_PROCESSING( xExpectedIdleTime );       // Turn ON all Periphials in this function
        // Any interrupt may have woken us up
        // Before renable interrupts, check how many ticks the processor has been in SLEEP
        // Adjust xTickCount via vTaskStepTick( Delta_Sleep )
        // to keep xTickCount up to date, as if ticks have been running all along
        New_Timer = am_hal_stimer_counter_get();
        Delta_Sleep = (signed long) New_Timer - (signed long) g_lastSTimerVal;
        g_lastSTimerVal = New_Timer - Delta_Sleep%ulTimerCountsForOneTick;
#else
        New_Timer = am_hal_ctimer_read(configCTIMER_NUM, AM_HAL_CTIMER_BOTH);
        // INTSTAT check is needed to handle a possible case where the we came here without timer
        // incrementing at all....the value will still say 0, but it does not mean it expired
        if ((New_Timer == 0) && ((am_hal_ctimer_int_status_get(false) & (1 << configCTIMER_NUM*2))))
            // The timer ran to completion and reset itself
            Delta_Sleep = ulReloadValue;
            // Clear the INTSTAT to prevent interrupt handler from counting an extra tick
            am_hal_ctimer_int_clear((1 << configCTIMER_NUM*2));
        } else
            Delta_Sleep = New_Timer; // Indicates the time elapsed since we slept
        Delta_Sleep /= ulTimerCountsForOneTick;
        // Correct System Tick after Sleep
        vTaskStepTick( Delta_Sleep );
		/* Restart System Tick */
        // Clear the interrupt - to avoid extra tick counting in ISR
        am_hal_stimer_int_clear(AM_HAL_STIMER_INT_COMPAREA | AM_HAL_STIMER_INT_COMPAREB);
#else
        am_hal_stimer_int_clear(AM_HAL_STIMER_INT_COMPAREA);
        am_hal_stimer_compare_delta_set(0, ulTimerCountsForOneTick);
        am_hal_stimer_compare_delta_set(1, ulTimerCountsForOneTick+1);
#else
        am_hal_ctimer_compare_set(configCTIMER_NUM, AM_HAL_CTIMER_BOTH, 0, ulTimerCountsForOneTick);
        /* Re-enable interrupts - see comments above __disable_irq() call above. */
#endif /* #if configUSE_TICKLESS_IDLE = 2 */
// Events associated with STimer CMP0 Interrupt
//  This is the FreeRTOS System Timer
//  Real Time events must be controlled by FreeRTOS as the Stimer is also used for sleep functions.
//  At any time the Stimer->Cmp0 interrupt can be a regular Tick interrupt or
//  an interrupt from a long Deep_Sleep().
//  The Deep Sleep in entered in Port.c->vPortSuppressTicksAndSleep() which is
//  entered from the IDLE task.
//  If no tasks are READY to run, vPortSuppressTicksAndSleep() is called.
//  See tasks.c-> portTASK_FUNCTION(...)
void
xPortStimerTickHandler(uint32_t delta)
    uint32_t remainder = 0;
    uint32_t curSTimer;
    uint32_t timerCounts;
    uint32_t numTicksElapsed;
    BaseType_t ctxtSwitchReqd = pdFALSE;
    curSTimer = am_hal_stimer_counter_get();
    // Configure the STIMER->COMPARE_0
    am_hal_stimer_compare_delta_set(0, (ulTimerCountsForOneTick-delta));
    am_hal_stimer_compare_delta_set(1, (ulTimerCountsForOneTick-delta+1));
    timerCounts = curSTimer - g_lastSTimerVal;
    numTicksElapsed = timerCounts/ulTimerCountsForOneTick;
    remainder = timerCounts % ulTimerCountsForOneTick;
    g_lastSTimerVal = curSTimer - remainder;
    // This is a timer a0 interrupt, perform the necessary functions
    // for the tick ISR.
    (void) portSET_INTERRUPT_MASK_FROM_ISR();
        // Increment RTOS tick
        // Allowing for need to increment the tick more than one... to avoid accumulation of
        // error in case of interrupt latencies
        while (numTicksElapsed--)
            ctxtSwitchReqd = (( xTaskIncrementTick() != pdFALSE ) ? pdTRUE : ctxtSwitchReqd);
        if ( ctxtSwitchReqd != pdFALSE )
            // A context switch is required.  Context switching is
            // performed in the PendSV interrupt. Pend the PendSV
            // interrupt.
    portCLEAR_INTERRUPT_MASK_FROM_ISR(0);
// Interrupt handler for the STIMER module Compare 0.
void
am_stimer_cmpr0_isr(void)
    // Check the timer interrupt status.
    uint32_t ui32Status = am_hal_stimer_int_status_get(false);
    if (ui32Status & AM_HAL_STIMER_INT_COMPAREA)
        // Run handlers for the various possible timer events.
        xPortStimerTickHandler(0);
uint32_t gNumCmpB = 0;
void
am_stimer_cmpr1_isr(void)
    if (ui32Status & AM_HAL_STIMER_INT_COMPAREB)
        am_hal_stimer_int_clear(AM_HAL_STIMER_INT_COMPAREB);
        gNumCmpB++;
        xPortStimerTickHandler(1);
#else // Use CTimer
// Events associated with CTimer 0
void
xPortCTimer0TickHandler(void)
    // Restart the one-shot timer for next 'tick'
        if ( xTaskIncrementTick() != pdFALSE )
            // interrupt.
#endif // AM_FREERTOS_USE_STIMER_FOR_TICK
    uint32_t oldCfg;
        ulTimerCountsForOneTick = (configSTIMER_CLOCK_HZ /configTICK_RATE_HZ) ; //( configSYSTICK_CLOCK_HZ / configTICK_RATE_HZ );
        xMaximumPossibleSuppressedTicks = portMAX_32_BIT_NUMBER / ulTimerCountsForOneTick - 1;
#else
        xMaximumPossibleSuppressedTicks = portMAX_32_BIT_NUMBER / ulTimerCountsForOneTick;
    am_hal_stimer_int_enable(AM_HAL_STIMER_INT_COMPAREA | AM_HAL_STIMER_INT_COMPAREB);
#else
    am_hal_stimer_int_enable(AM_HAL_STIMER_INT_COMPAREA);
    // Enable the timer interrupt in the NVIC, making sure to use the
    // appropriate priority level.
#if AM_CMSIS_REGS
    NVIC_SetPriority(STIMER_CMPR0_IRQn, NVIC_configKERNEL_INTERRUPT_PRIORITY);
    NVIC_EnableIRQ(STIMER_CMPR0_IRQn);
#else // AM_CMSIS_REGS
    am_hal_interrupt_priority_set(AM_HAL_INTERRUPT_STIMER_CMPR0, configKERNEL_INTERRUPT_PRIORITY);
    am_hal_interrupt_enable(AM_HAL_INTERRUPT_STIMER_CMPR0);
#endif // AM_CMSIS_REGS
#if AM_CMSIS_REGS
    NVIC_SetPriority(STIMER_CMPR1_IRQn, NVIC_configKERNEL_INTERRUPT_PRIORITY);
    NVIC_EnableIRQ(STIMER_CMPR1_IRQn);
    am_hal_interrupt_priority_set(AM_HAL_INTERRUPT_STIMER_CMPR1, configKERNEL_INTERRUPT_PRIORITY);
    am_hal_interrupt_enable(AM_HAL_INTERRUPT_STIMER_CMPR1);
    oldCfg = am_hal_stimer_config(AM_HAL_STIMER_CFG_FREEZE);
    g_lastSTimerVal = am_hal_stimer_counter_get();
#if AM_CMSIS_REGS
    am_hal_stimer_config((oldCfg & ~(AM_HAL_STIMER_CFG_FREEZE | CTIMER_STCFG_CLKSEL_Msk)) | configSTIMER_CLOCK | AM_HAL_STIMER_CFG_COMPARE_A_ENABLE | AM_HAL_STIMER_CFG_COMPARE_B_ENABLE);
    am_hal_stimer_config((oldCfg & ~(AM_HAL_STIMER_CFG_FREEZE|AM_REG_CTIMER_STCFG_CLKSEL_M)) | configSTIMER_CLOCK | AM_HAL_STIMER_CFG_COMPARE_A_ENABLE | AM_HAL_STIMER_CFG_COMPARE_B_ENABLE);
#else
#if AM_CMSIS_REGS
    am_hal_stimer_config((oldCfg & ~(AM_HAL_STIMER_CFG_FREEZE | CTIMER_STCFG_CLKSEL_Msk)) | configSTIMER_CLOCK | AM_HAL_STIMER_CFG_COMPARE_A_ENABLE);
    am_hal_stimer_config((oldCfg & ~(AM_HAL_STIMER_CFG_FREEZE|AM_REG_CTIMER_STCFG_CLKSEL_M)) | configSTIMER_CLOCK | AM_HAL_STIMER_CFG_COMPARE_A_ENABLE);
#else
        ulTimerCountsForOneTick = ( configCTIMER_CLOCK_HZ/configTICK_RATE_HZ) ;
    am_hal_ctimer_config_t cTimer0Config =
        .ui32Link = 1,
        .ui32TimerAConfig = (configCTIMER_CLOCK |
                             AM_HAL_CTIMER_FN_ONCE|
                             AM_HAL_CTIMER_INT_ENABLE),
        .ui32TimerBConfig = 0
    // Configure the timer frequency and mode.
    am_hal_ctimer_config(configCTIMER_NUM, &cTimer0Config);
    // Set the timeout interval
    // Enable the interrupt for timer A0
    am_hal_ctimer_int_enable(AM_FREERTOS_CTIMER_INT);
#if AM_CMSIS_REGS
    NVIC_SetPriority(CTIMER_IRQn, NVIC_configKERNEL_INTERRUPT_PRIORITY);
    am_hal_ctimer_int_register(AM_FREERTOS_CTIMER_INT, xPortCTimer0TickHandler);
    NVIC_EnableIRQ(CTIMER_IRQn);
    am_hal_interrupt_priority_set(AM_HAL_INTERRUPT_CTIMER, configKERNEL_INTERRUPT_PRIORITY);
    am_hal_interrupt_enable(AM_HAL_INTERRUPT_CTIMER);
    // Enable the timer.
Thanks - I can confirm the vPortSuppressTicksAndSleep() function is not provided by us. Probably best to ask the vendor directly.
What is the difference between your and vendor’s version? Can I copy and paste your version? Is it going to work by just changing this function?
The original V10.1.1 version is here: https://github.com/FreeRTOS/FreeRTOS-Kernel/blob/V10.1.1/FreeRTOS/Source/portable/IAR/ARM_CM4F/port.c
Hey,
I apologize for bringing up this old thread, but I deal with the identical problem.
Utilizing LPTIMER to override the sys_tick and deep sleep STOP1 mode on an STM32WB55 MCU.
For vPortSuppressTicksAndSleep, I have adjusted the code, but the general idea remains the same.
It appears that the assert is triggered when a series of consecutive interrupts arrive, causing the MCU to wake up from sleep.
This code:
* out of sleep mode to execute immediately. see comments above
* __disable_interrupt() call above. */
__asm volatile ( “cpsie i” ::: “memory” );
__asm volatile ( “dsb” );
__asm volatile ( “isb” );
Causes the interrupt handler to handle the interrupts…
However, since I have a burst of interrupts (1-2 seconds) and since the SYSTICK continue to counts, the assert is hit.
Question - what is the risk of removing this code and just enable the interrupt after re-calculate the missing ticks (except from some time drift)?
Thanks,
Dagan
The only issue with waiting until after the tick-count correction to enable interrupts is increased interrupt latency. Your ISR will be delayed while the tickless code calculates and corrects.
For clarity, are you saying you have ISR executions back-to-back so intensely that the tickless code does not even execute for more than one tick duration? Is that expected operation for your application?
Well - this is only my theory. I still not 100% sure why I’m hiting this assert…
The interrupt burst is a signal from analog microphone that should wake-up my system.
The interrupts frequency is ~16KHz (~60uSec) with a pulse burst width of few miliseconds, followed by a few mSec gap and another pulse… lasting 1-2 seconds total.
I thought of another option - disable the SYSTICK before enable the interrupt, so it will not count during the burst.
I’m aware of the possible time drifting.
Understood. As a patch to keep things moving, you could add code to limit the value you pass to vTaskStepTick(). The limit is xExpectedIdleTime - 1. That will stop the assertion failures and allow you to move forward to determine what is happening in your software. Specifically, do you really have a few ms’ worth of continuous ISR execution?
For perspective, the official version of vPortSuppressTicksAndSleep() provided by FreeRTOS already limits the value passed to vTaskStepTick(). But it does so implicitly, without the kind of explicit code I’m suggesting you add to your custom version of vPortSuppressTicksAndSleep(). In fact, can you post your custom version?
