vTaksDelay stops scheduler without resuming it after a few calls
I found a bug in the STM32 code when using a separate hardware timer for ticks, and the tick priority is not set correctly. I added a workaround
int main(void)
/* USER CODE BEGIN 1 */
/* USER CODE END 1 */
/* MCU Configuration--------------------------------------------------------*/
/* Reset of all peripherals, Initializes the Flash interface and the Systick. */
HAL_Init();
/* USER CODE BEGIN Init /
workaround for uwTickPrio not set to same priority in second call to initialise
  • timer.
    uwTickPrio = TICK_INT_PRIORITY;
/* USER CODE END Init */
ST are aware of this issue and will correct in future versions.
Thanks for sharing. I added the fix, but unfortunately it does not fix my problem.
It sounds like you are just suffering from a data corruption. Previously you reported adding one additional test variable caused corruption when calling xTaskCreateStatic() (the assert that the stack was NULL), which may even point to the linker script being wrong. In any case, it sounds like that assert gets triggered before the scheduler starts, which will make it much easier to debug. If data watchpoints aren’t working then view the variable in the debugger as you step through the code to the point you can see the variable getting written over.
I wish I could just take my time and step through the code, but I can’t, since the modem will then time-out as the keep alive message is not sent during debugging pause.
I have to figure out another way to see what is executed just prior the the assert.
Another thing that complicates things, is when I re-run the same code, the moment the problem occurs varies wildly. It can happen at any random iteration and just stepping through a single iteration already is hundreds of lines. Like finding a needle in a haystack clicking and fighting against the timeout of the modem, in which I’m not succeeding.
Previously you wrote:
Which sounds like the assert happens before you have created the task, so I am assuming that is before you start the scheduler and before you start using the modem. Is that right? If so you really need to find the cause of this assert before trying to find the cause of the assert you originally posted about as they are probably both symptoms of the same issue. Of the two asserts, the one in xTaskCreateStatic() is going to be much easier to debug, especially as it is so reproducible.
Can you try increasing the stack size of StartDefaultTask:
  osThreadDef(defaultTask, StartDefaultTask, osPriorityNormal, 0, 4096);
  defaultTaskHandle = osThreadCreate(osThread(defaultTask), NULL);
Separately, I would suggest to not mix FreeRTOS and CMSIS API.
Please share the debugger screenhost for this too.
I increased the stack size of my default task from 256 to 4096. Then my task would not start-up. The only thing which was then running was the idle task.
I changed the stack size to 1024 and all my problems were gone!
I specifically implemented the stack overflow hook and tested the hook with a very small stack, which worked. So when I ran with a 256 stack and the hook was not triggered I assumed 256 was big enough. But apparently it still wasn’t and changing it to 1024 solved the problem. A problem that looked like a memory corruption, which sent me on a wild goose chase for a couple of days…
The remaining question I have now is; why does my task not run when I change the stack size to 4096? I’m running on a uC which has a generous 128kB RAM.
Now that MQTT is up and running, I will need an additional task for OTA, which requires a larger stack, so I need to get it running with larger stacks.
One possible explanation is that the task creation failed because the memory allocation for large stack failed. You can and should check the return of xTaskCreate to ensure that the task was created successfully.
Also there is a configuration item / define for the (FreeRTOS) heap size.
See FreeRTOS - Memory management options for the FreeRTOS small footprint, professional grade, real time kernel (scheduler) for the FreeRTOS heap implementations in case you’re using one of them.
Thanks, that did the trick. I ramped up the heap size and am now able to use larger stack sizes.
This topic can now be closed.
I would recommend reading through the free-to-download book (which I’m in the process of very slowly updating…) - it will save you a lot of time.
Thanks, I will. Really appreciate the help here on the forum, keep up the good work!
