k1mgy wrote on Thursday, November 02, 2017:
After a few days of head pounding, I’ve traced a problem: enabling vTaskList with:
#define configUSE_STATS_FORMATTING_FUNCTIONS 1
…causes FreeRTOS to halt at vPortFree().
vTaskList worked fine in 7.0 and 7.3, and did not require setting these constants.
I have not touched the memory management scheme. Looked at which memmang file has been selected and see** heap_1.c**
How to fix?
Here’s the entire config:
#ifndef FREERTOS_CONFIG_H
#define FREERTOS_CONFIG_H
/* For documentation for all the configuration symbols, go to:
* http://www.freertos.org/a00110.html.
#if defined (__GNUC__) || defined (__ICCARM__)
/* Important: put #includes here unless they are also meant for the assembler.
#include <stdint.h>
void assert_triggered( const char * file, uint32_t line );
#define configUSE_IDLE_HOOK 0
#define configUSE_TICK_HOOK 0
#define configPRIO_BITS 2
#define configCPU_CLOCK_HZ ( 8000000 )
#define configTICK_RATE_HZ ( ( TickType_t ) 1000 )
#define configMAX_PRIORITIES ( ( uint32_t ) 5 )
#define configMINIMAL_STACK_SIZE ( ( uint16_t ) 100 )
/* configTOTAL_HEAP_SIZE is not used when heap_3.c is used. */
#define configTOTAL_HEAP_SIZE ( ( size_t ) ( 15000 ) )
#define configMAX_TASK_NAME_LEN ( 8 )
#define configUSE_MUTEXES 1
#define configQUEUE_REGISTRY_SIZE 0
#define configCHECK_FOR_STACK_OVERFLOW 0
#define configUSE_RECURSIVE_MUTEXES 1
#define configUSE_MALLOC_FAILED_HOOK 0
#define configUSE_COUNTING_SEMAPHORES 1
#define configUSE_QUEUE_SETS 1
#define configGENERATE_RUN_TIME_STATS 0
#define configENABLE_BACKWARD_COMPATIBILITY 1
/* Co-routine definitions. */
#define configMAX_CO_ROUTINE_PRIORITIES ( 2 )
/* Software timer definitions. */
#define configUSE_TIMERS 1
#define configTIMER_TASK_PRIORITY ( 2 )
#define configTIMER_QUEUE_LENGTH 2
#define configTIMER_TASK_STACK_DEPTH ( 80 )
#define INCLUDE_vTaskPrioritySet 1
#define INCLUDE_uxTaskPriorityGet 1
#define INCLUDE_vTaskDelete 1
#define INCLUDE_xResumeFromISR 1
#define INCLUDE_vTaskDelayUntil 1
#define INCLUDE_vTaskDelay 1
#define INCLUDE_xTaskGetSchedulerState 1
#define INCLUDE_xTaskGetCurrentTaskHandle 1
#define INCLUDE_uxTaskGetStackHighWaterMark 0
#define INCLUDE_xTaskGetIdleTaskHandle 0
#define INCLUDE_xTimerGetTimerDaemonTaskHandle 0
#define INCLUDE_pcTaskGetTaskName 0
#define INCLUDE_eTaskGetState 0
/* Normal assert() semantics without relying on the provision of an assert.h
header file. */
#define configASSERT( x ) \
if( ( x ) == 0 ) { taskDISABLE_INTERRUPTS(); for( ;; ); }
/* Definitions that map the FreeRTOS port interrupt handlers to their CMSIS
standard names - or at least those used in the unmodified vector table. */
function. */
#define configLIBRARY_LOWEST_INTERRUPT_PRIORITY 0x0f
routine that makes calls to interrupt safe FreeRTOS API functions. DO NOT CALL
#define configLIBRARY_MAX_SYSCALL_INTERRUPT_PRIORITY 10
/* Interrupt priorities used by the kernel port layer itself. These are generic
#define configKERNEL_INTERRUPT_PRIORITY ( configLIBRARY_LOWEST_INTERRUPT_PRIORITY << (8 - configPRIO_BITS) )
#define configMAX_SYSCALL_INTERRUPT_PRIORITY ( configLIBRARY_MAX_SYSCALL_INTERRUPT_PRIORITY << (8 - configPRIO_BITS) )
