V5.0.0 under Borland
rtel wrote on Monday, May 26, 2008:
[moved from support request tracker - please just use the forum for support]
The port flashlite RTOSDEMO in freeRtos version 5.0 with Borland C++ 4.52
not compile is 100% error all line and crash the IDE Borland c++.
PS: Not show message of error, show only Line count and File count.
I don’t currently have Borland installed so cannot try it.  However it seems unlikely that source code could make the IDE crash, could it be your installation?  Try performing a full clean first - deleting all object files before performing the build.
fpinheiro wrote on Tuesday, May 27, 2008:
Hi Richard
The install of Borland C++ is the same who I compile and work normal the FreeRTOS V4.1.3 port Flashlite from JKMicro.
If I try to compile the V5.0 the box progress compiler is half hour counting errors and files if I try to cancel the IDE Crash.
Regards
Pinheiro.
rtel wrote on Tuesday, May 27, 2008:
Did you try removing all .obj file first?
Yes, already removed all obj and still remains the same problem.
Regards
fpinheiro wrote on Friday, May 30, 2008:
Hi Richard
I downloaded the version 4.8.0 and compiled with Borland c++ 4.52 and all is Ok. but the version 5.0.0 again bad. crash the ide.
Regards
Pinheiro
fpinheiro wrote on Saturday, May 31, 2008:
Hi Richard
Too the version 5.0.2 have the same problem, crash the IDE when compile the file portable.h
Regards
Pinheiro.
fpinheiro wrote on Friday, June 06, 2008:
Hi Richard
Too the version 5.0.2 have the same problem who version 5.0.0, crash the IDE when compile the file portable.h
Regards
Pinheiro.
