usStackDepth not showing any effect in POSIX simulation layer
Hi
On Posix Simulation Layer, I’m creating task using:
xTaskCreate(task_1, "Task-1", 100, "\nHello world from task1", 1, Task1_handle);
Task:
static void task_1(void* parameter) {
    int i = 0;
    printf("%s\n", (char*) parameter);
    long a[250];
    for (int i = 0; i < 250; i++) {
        a[i] = i+i;
        printf("%lu ", a[i]);
    while(1) {
        i++;
I performed this experiment with heap_1.c, heap_2.c as well as with heap_4.c
Problem: I was expecting it to throw some error as my task_1 was using more memory than being allocated in the xTaskCreate API.
But my task ran smoothly. Any leads will be appreciated. I’m a beginner on FreeRTOS.
PS: I’m not using any board. I’m experimenting on the Posix Simulation layer.
Hello bluechip!
This is due to the Posix Simulator task stack having a restriction on the true minimum size. If you read the final section on this page it mentions…
A limitation exists for the minimal stack size that can be created. This limitation is platform dependent and is equal to PTHREAD_STACK_MIN…As a workaround, always pass a stack of size PTHREAD_STACK_MIN if the desired stack is less than PTHREAD_STACK_MIN when running on a Posix port.
It is almost certain that PTHREAD_STACK_MIN is larger than the stack size of 100 supplied which explains why you’re not seeing stack failures.
For more on why this is the minimum stack size, see the “Principle of Operation” section on this page.
Thanks a lot! This explains.
No problem! If you’re happy with the answer, feel free to mark my comment as the solution.
