The switch case (loop) is ok. Otherwise the compiler would tell you if it couldn’t implicitly convert the case constants matching the type of the switch variable.
Do you run the application with compile and linker optimization disabled (for GCC it’s the -O0 CFLAG and LTO shouldn’t be used for debugging, too) ?
Debuggers seem to unpredictable jump around the source code if debugging optimized builds because the 1:1 relation of source lines and executed assembly is then not longer fully provided.
Using -Og (for GCC) works in a acceptable way but it’s a compromise. For instance you won’t be able to inspect all local variables because they’re often optimized out by using registers.
Stack size of 128 words is not that much but could be sufficient because the code is not yet complex. And it really should be possible to step through those few lines of code with the debugger. You’d be completely lost once your app grows and get’s more complex without it.
Please also see this development hints you should consider to take into account.
