Unit Test Strategy
I can’t see any other thread created by accident or by purpose. Just before the crash there are two quick task switches. This is due to that freq_mgr_task() calls vTaskDelay() immediatly in waiting for a notification from the system control to go from config state to operating state (basically no units are allowed to call each other until operating state).
Actually, one thing that comes to mind is that the function create_nvm_file() calls fwrite(). My CicNvm is ported to read and write to Linux file system, so I save NVM area files before CicSettings is started (which reads settings from CicNvm) Wonder if that is causing problems…
I’ve created a log where I print task names so it is easy to match to gdb LWP’s.
Starting program: /home/corebon/work/cic/exe/CIC_GTEST.exe
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
[New Thread 0x7ffff78d8700 (LWP 5584)]
[os/FreeRTOS/tasks.c:xTaskCreate] gtest_task
[New Thread 0x7ffff0019640 (LWP 5585)]
[os/FreeRTOS/tasks.c:xTaskCreate] IDLE
[New Thread 0x7ffff70d7700 (LWP 5586)]
[os/FreeRTOS/tasks.c:xTaskCreate] Tmr Svc
[New Thread 0x7ffff68d6700 (LWP 5587)]
[os/FreeRTOS/tasks.c:vTaskSwitchContext:3018] Tmr Svc
[os/FreeRTOS/tasks.c:vTaskSwitchContext:3094] pxCurrentTCB = gtest_task
[==========] Running 38 tests from 4 test suites.
[----------] Global test environment set-up.
[----------] 32 tests from CicCommon
[ RUN      ] CicCommon.FileMacro
[       OK ] CicCommon.FileMacro (0 ms)
[ RUN      ] CicCommon.SEC_TO_MS
[       OK ] CicCommon.SEC_TO_MS (0 ms)
[ RUN      ] CicCommon.SEC_TO_US
[       OK ] CicCommon.SEC_TO_US (0 ms)
[ RUN      ] CicCommon.MIN_TO_SEC
[       OK ] CicCommon.MIN_TO_SEC (0 ms)
[ RUN      ] CicCommon.MIN_TO_MS
[       OK ] CicCommon.MIN_TO_MS (0 ms)
[ RUN      ] CicCommon.MS_TO_SEC
[       OK ] CicCommon.MS_TO_SEC (0 ms)
[ RUN      ] CicCommon.NS_TO_MS
[       OK ] CicCommon.NS_TO_MS (0 ms)
[ RUN      ] CicCommon.NS_TO_US
[       OK ] CicCommon.NS_TO_US (0 ms)
[ RUN      ] CicCommon.SIZE_OF_ARRAY
[       OK ] CicCommon.SIZE_OF_ARRAY (0 ms)
[       OK ] CicCommon.MIN (0 ms)
[ RUN      ] CicCommon.MAX
[       OK ] CicCommon.MAX (0 ms)
[ RUN      ] CicCommon.DIFF
[       OK ] CicCommon.DIFF (0 ms)
[ RUN      ] CicCommon.ABS
[       OK ] CicCommon.ABS (0 ms)
[ RUN      ] CicCommon.CONSTRAIN
[       OK ] CicCommon.CONSTRAIN (0 ms)
[ RUN      ] CicCommon.CONSTRAIN_U_TO_INT32
[       OK ] CicCommon.CONSTRAIN_U_TO_INT32 (0 ms)
[ RUN      ] CicCommon.ALIGN_UP
[       OK ] CicCommon.ALIGN_UP (0 ms)
[ RUN      ] CicCommon.ALIGN_DOWN
[       OK ] CicCommon.ALIGN_DOWN (0 ms)
[ RUN      ] CicCommon.PERCENT_OF
[       OK ] CicCommon.PERCENT_OF (0 ms)
[ RUN      ] CicCommon.SIGN
[       OK ] CicCommon.SIGN (0 ms)
[ RUN      ] CicCommon.INT_ROUND
[       OK ] CicCommon.INT_ROUND (0 ms)
[ RUN      ] CicCommon.DBL_ROUND
[       OK ] CicCommon.DBL_ROUND (0 ms)
[ RUN      ] CicCommon.byteswap16
[       OK ] CicCommon.byteswap16 (0 ms)
[ RUN      ] CicCommon.byteswap32
[       OK ] CicCommon.byteswap32 (0 ms)
[ RUN      ] CicCommon.CIC_IS_BIT_SET
[       OK ] CicCommon.CIC_IS_BIT_SET (0 ms)
[ RUN      ] CicCommon.CIC_SET_BIT
[       OK ] CicCommon.CIC_SET_BIT (0 ms)
[ RUN      ] CicCommon.CIC_COND_SET_BIT
[       OK ] CicCommon.CIC_COND_SET_BIT (0 ms)
[ RUN      ] CicCommon.cic_strtod
[       OK ] CicCommon.cic_strtod (0 ms)
[ RUN      ] CicCommon.cic_strtoul_dec
[       OK ] CicCommon.cic_strtoul_dec (0 ms)
[ RUN      ] CicCommon.cic_strtoull_dec
[       OK ] CicCommon.cic_strtoull_dec (0 ms)
[ RUN      ] CicCommon.cic_strtoul_hex
[       OK ] CicCommon.cic_strtoul_hex (0 ms)
[ RUN      ] CicCommon.cic_print_double
[       OK ] CicCommon.cic_print_double (0 ms)
[ RUN      ] CicCommon.byteswap16_array
[       OK ] CicCommon.byteswap16_array (0 ms)
[----------] 32 tests from CicCommon (0 ms total)
[----------] 2 tests from CicErrorCounter
[ RUN      ] CicErrorCounter.register_error_stdout
[       OK ] CicErrorCounter.register_error_stdout (1 ms)
[ RUN      ] CicErrorCounter.register_error_file
[       OK ] CicErrorCounter.register_error_file (0 ms)
[----------] 2 tests from CicErrorCounter (1 ms total)
[----------] 2 tests from CicCommandTest
[ RUN      ] CicCommandTest.subscribeOk
[cic_freq_mgr.cpp:161] (0 == 0x00000000)
[       OK ] CicCommandTest.subscribeOk (0 ms)
[ RUN      ] CicCommandTest.subscribeFail
[       OK ] CicCommandTest.subscribeFail (0 ms)
[----------] 2 tests from CicCommandTest (0 ms total)
[----------] 2 tests from CicFreqManagerTest
[ RUN      ] CicFreqManagerTest.SetGetFrequency
[os/FreeRTOS/tasks.c:xTaskCreate] freq_mgr_task
[New Thread 0x7ffff60d5700 (LWP 5588)]
[cic_freq_mgr_test.cpp:96] Settings file: 'cic_freq_mgr_settings.txt'
[os/FreeRTOS/tasks.c:xTaskPriorityDisinherit:pxTCB]         gtest_task
[os/FreeRTOS/tasks.c:xTaskPriorityDisinherit:pxCurrentTCB]  gtest_task
[os/FreeRTOS/tasks.c:vTaskSwitchContext:3094] pxCurrentTCB = freq_mgr_task
[os/FreeRTOS/tasks.c:xTaskPriorityDisinherit:pxTCB]         freq_mgr_task
ASSERT-os/FreeRTOS/tasks.c-4182
Thread 3 "CIC_GTEST.exe" received signal SIGABRT, Aborted.
[Switching to Thread 0x7ffff0019640 (LWP 5585)]
__GI_raise (sig=sig@entry=6) at ../sysdeps/unix/sysv/linux/raise.c:50
50	../sysdeps/unix/sysv/linux/raise.c: No such file or directory.
(gdb) thread apply all bt
Thread 6 (Thread 0x7ffff60d5700 (LWP 5588)):
#0  futex_wait_cancelable (private=, expected=0, futex_word=0x7fffe800aaa4) at ../sysdeps/nptl/futex-internal.h:183
#1  __pthread_cond_wait_common (abstime=0x0, clockid=0, mutex=0x7fffe800aa50, cond=0x7fffe800aa78) at pthread_cond_wait.c:508
#2  __pthread_cond_wait (cond=0x7fffe800aa78, mutex=0x7fffe800aa50) at pthread_cond_wait.c:638
#3  0x0000555555584376 in event_wait (ev=0x7fffe800aa50) at os/FreeRTOS/portable/ThirdParty/GCC/Posix/utils/wait_for_event.c:41
#4  0x0000555555583c54 in prvSuspendSelf (thread=thread@entry=0x7fffe8004a88) at os/FreeRTOS/portable/ThirdParty/GCC/Posix/port.c:496
#5  0x0000555555583c9b in prvSwitchThread (pxThreadToResume=, pxThreadToSuspend=pxThreadToSuspend@entry=0x7fffe8004a88) at os/FreeRTOS/portable/ThirdParty/GCC/Posix/port.c:474
#6  0x0000555555583d28 in vPortYieldFromISR () at os/FreeRTOS/portable/ThirdParty/GCC/Posix/port.c:279
#7  0x0000555555584175 in vPortYield () at os/FreeRTOS/portable/ThirdParty/GCC/Posix/port.c:287
#8  0x0000555555582112 in vTaskDelay (xTicksToDelay=xTicksToDelay@entry=100) at os/FreeRTOS/tasks.c:1371
#9  0x00005555555a2d7e in CicFreqManager::freq_mgr_task (this=0x7fffe800a490) at cic/src/cic_freq_mgr.cpp:398
#10 0x00005555555a2e69 in CicFreqManager::freq_mgr_task_entry (param=) at cic/src/cic_freq_mgr.cpp:392
#11 0x000055555558403f in prvWaitForStart (pvParams=0x7fffe8004a88) at os/FreeRTOS/portable/ThirdParty/GCC/Posix/port.c:440
#12 0x00007ffff79fe609 in start_thread (arg=) at pthread_create.c:477
#13 0x00007ffff7ee2293 in clone () at ../sysdeps/unix/sysv/linux/x86_64/clone.S:95
Thread 5 (Thread 0x7ffff68d6700 (LWP 5587)):
#0  futex_wait_cancelable (private=, expected=0, futex_word=0x7ffff001bda4) at ../sysdeps/nptl/futex-internal.h:183
#1  __pthread_cond_wait_common (abstime=0x0, clockid=0, mutex=0x7ffff001bd50, cond=0x7ffff001bd78) at pthread_cond_wait.c:508
#2  __pthread_cond_wait (cond=0x7ffff001bd78, mutex=0x7ffff001bd50) at pthread_cond_wait.c:638
#3  0x0000555555584376 in event_wait (ev=0x7ffff001bd50) at os/FreeRTOS/portable/ThirdParty/GCC/Posix/utils/wait_for_event.c:41
#4  0x0000555555583c54 in prvSuspendSelf (thread=thread@entry=0x7ffff001bc48) at os/FreeRTOS/portable/ThirdParty/GCC/Posix/port.c:496
#5  0x0000555555583c9b in prvSwitchThread (pxThreadToResume=, pxThreadToSuspend=pxThreadToSuspend@entry=0x7ffff001bc48) at os/FreeRTOS/portable/ThirdParty/GCC/Posix/port.c:474
#8  0x0000555555583a14 in prvProcessTimerOrBlockTask (xNextExpireTime=, xListWasEmpty=1) at os/FreeRTOS/timers.c:633
#9  0x0000555555583bd6 in prvTimerTask (pvParameters=) at os/FreeRTOS/timers.c:579
#10 0x000055555558403f in prvWaitForStart (pvParams=0x7ffff001bc48) at os/FreeRTOS/portable/ThirdParty/GCC/Posix/port.c:440
#11 0x00007ffff79fe609 in start_thread (arg=) at pthread_create.c:477
#12 0x00007ffff7ee2293 in clone () at ../sysdeps/unix/sysv/linux/x86_64/clone.S:95
Thread 4 (Thread 0x7ffff70d7700 (LWP 5586)):
#0  futex_wait_cancelable (private=, expected=0, futex_word=0x7ffff001ab20) at ../sysdeps/nptl/futex-internal.h:183
#1  __pthread_cond_wait_common (abstime=0x0, clockid=0, mutex=0x7ffff001aad0, cond=0x7ffff001aaf8) at pthread_cond_wait.c:508
#2  __pthread_cond_wait (cond=0x7ffff001aaf8, mutex=0x7ffff001aad0) at pthread_cond_wait.c:638
#3  0x0000555555584376 in event_wait (ev=0x7ffff001aad0) at os/FreeRTOS/portable/ThirdParty/GCC/Posix/utils/wait_for_event.c:41
#4  0x0000555555583c54 in prvSuspendSelf (thread=thread@entry=0x7ffff001a9c8) at os/FreeRTOS/portable/ThirdParty/GCC/Posix/port.c:496
#5  0x0000555555584029 in prvWaitForStart (pvParams=0x7ffff001a9c8) at os/FreeRTOS/portable/ThirdParty/GCC/Posix/port.c:433
#6  0x00007ffff79fe609 in start_thread (arg=) at pthread_create.c:477
#7  0x00007ffff7ee2293 in clone () at ../sysdeps/unix/sysv/linux/x86_64/clone.S:95
Thread 3 (Thread 0x7ffff0019640 (LWP 5585)):
#0  __GI_raise (sig=sig@entry=6) at ../sysdeps/unix/sysv/linux/raise.c:50
#1  0x00007ffff7de5859 in __GI_abort () at abort.c:79
#2  0x000055555558505c in cic_assert_failed (file=file@entry=0x55555562c014 "os/FreeRTOS/tasks.c", line=line@entry=4182) at gtest/ports/src/cic_common_port.c:29
#3  0x0000555555582ba9 in xTaskPriorityDisinherit (pxMutexHolder=0x7fffe8004ac0) at os/FreeRTOS/tasks.c:4182
#4  0x0000555555580856 in prvCopyDataToQueue (pxQueue=pxQueue@entry=0x7fffe800a3a0, pvItemToQueue=pvItemToQueue@entry=0x0, xPosition=xPosition@entry=0) at os/FreeRTOS/queue.c:2144
#5  0x0000555555580b98 in xQueueGenericSend (xQueue=xQueue@entry=0x7fffe800a3a0, pvItemToQueue=pvItemToQueue@entry=0x0, xTicksToWait=, xTicksToWait@entry=0, xCopyPosition=xCopyPosition@entry=0) at os/FreeRTOS/queue.c:866
#6  0x00005555555c6980 in CicMutex::~CicMutex (this=0x7ffff0018a88, __in_chrg=) at cic/inc/cic_mutex.hpp:42
#7  CicNvm::write (this=, area=area@entry=CIC_NVM_AREA_PROD_DATA, buf_p=buf_p@entry=0x7fffe800ad60, buf_size=8) at gtes--Type  for more, q to quit, c to continue without paging--c
t/ports/src/cic_nvm_port.cpp:121
#8  0x00005555555d6bde in CicSettingsMock::create_nvm_file (this=this@entry=0x7fffe8003280, settings_file_name_p=settings_file_name_p@entry=0x55555563667d "prod_data.txt", nvm_area=nvm_area@entry=CIC_NVM_AREA_PROD_DATA) at gtest/mocks/src/cic_settings_mock.cpp:58
#9  0x00005555555d6c5d in CicSettingsMock::config (this=0x7fffe8003280, settings_file_name_p=settings_file_name_p@entry=0x5555556393df "cic_freq_mgr_settings.txt") at gtest/mocks/src/cic_settings_mock.cpp:42
#10 0x00005555555f96d8 in CicFreqManagerTest::SetUp (this=0x7fffe800a350) at gtest/tests/src/cic_freq_mgr_test.cpp:97
#11 0x000055555562b091 in testing::internal::HandleSehExceptionsInMethodIfSupported (location=0x55555563a473 "SetUp()", method=, object=0x7fffe800a350) at ./googletest/src/gtest.cc:2414
#12 testing::internal::HandleExceptionsInMethodIfSupported (object=object@entry=0x7fffe800a350, method=, location=location@entry=0x55555563a473 "SetUp()") at ./googletest/src/gtest.cc:2469
#13 0x000055555561e641 in testing::Test::Run (this=0x7fffe800a350) at ./googletest/src/gtest.cc:2503
#14 testing::Test::Run (this=0x7fffe800a350) at ./googletest/src/gtest.cc:2498
#15 0x000055555561e815 in testing::TestInfo::Run (this=0x5555556a21b0) at ./googletest/src/gtest.cc:2684
#16 testing::TestInfo::Run (this=0x5555556a21b0) at ./googletest/src/gtest.cc:2657
#17 0x000055555561e8fd in testing::TestSuite::Run (this=0x5555556a2380) at ./googletest/src/gtest.cc:2816
#18 testing::TestSuite::Run (this=0x5555556a2380) at ./googletest/src/gtest.cc:2795
#19 0x000055555561ee1c in testing::internal::UnitTestImpl::RunAllTests (this=0x55555569d0a0) at /usr/include/c++/9/bits/stl_vector.h:1040
#20 0x000055555562b601 in testing::internal::HandleSehExceptionsInMethodIfSupported (location=0x55555563b848 "auxiliary test code (environments or event listeners)", method=, object=0x55555569d0a0) at ./googletest/src/gtest.cc:2414
#21 testing::internal::HandleExceptionsInMethodIfSupported (object=0x55555569d0a0, method=, location=location@entry=0x55555563b848 "auxiliary test code (environments or event listeners)") at ./googletest/src/gtest.cc:2469
#22 0x000055555561f04c in testing::UnitTest::Run (this=0x55555568a3e0 ) at ./googletest/include/gtest/gtest.h:1412
#23 0x00005555555d6d21 in RUN_ALL_TESTS () at /usr/include/gtest/gtest.h:2490
#24 gtest_task (param=) at gtest/main_gtest.cpp:19
#25 0x000055555558403f in prvWaitForStart (pvParams=0x7ffff0019f48) at os/FreeRTOS/portable/ThirdParty/GCC/Posix/port.c:440
#26 0x00007ffff79fe609 in start_thread (arg=) at pthread_create.c:477
#27 0x00007ffff7ee2293 in clone () at ../sysdeps/unix/sysv/linux/x86_64/clone.S:95
Thread 2 (Thread 0x7ffff78d8700 (LWP 5584)):
#0  0x00007ffff7e07322 in __GI___sigtimedwait (set=set@entry=0x7ffff78d7e40, info=info@entry=0x7ffff78d7d80, timeout=timeout@entry=0x0) at ../sysdeps/unix/sysv/linux/sigtimedwait.c:29
#1  0x00007ffff7e066ac in __GI___sigwait (set=set@entry=0x7ffff78d7e40, sig=sig@entry=0x7ffff78d7e3c) at ../sysdeps/unix/sysv/linux/sigwait.c:28
#2  0x000055555558422e in xPortStartScheduler () at os/FreeRTOS/portable/ThirdParty/GCC/Posix/port.c:197
#3  0x0000555555581ccc in vTaskStartScheduler () at os/FreeRTOS/tasks.c:2090
#4  0x00005555555d6d02 in free_rtos_thread (data=) at gtest/main_gtest.cpp:50
#5  0x00007ffff79fe609 in start_thread (arg=) at pthread_create.c:477
#6  0x00007ffff7ee2293 in clone () at ../sysdeps/unix/sysv/linux/x86_64/clone.S:95
Thread 1 (Thread 0x7ffff78d9740 (LWP 5580)):
#0  vPortSystemTickHandler (sig=14) at os/FreeRTOS/portable/ThirdParty/GCC/Posix/port.c:369
#1
#2  0x00007ffff7ea03bf in __GI___clock_nanosleep (clock_id=clock_id@entry=0, flags=flags@entry=0, req=req@entry=0x7fffffffde90, rem=rem@entry=0x7fffffffde90) at ../sysdeps/unix/sysv/linux/clock_nanosleep.c:78
#3  0x00007ffff7ea6047 in __GI___nanosleep (requested_time=requested_time@entry=0x7fffffffde90, remaining=remaining@entry=0x7fffffffde90) at nanosleep.c:27
#4  0x00007ffff7ea5f7e in __sleep (seconds=0) at ../sysdeps/posix/sleep.c:55
#5  0x00005555555d6de6 in main (argc=, argv=) at gtest/main_gtest.cpp:72
(gdb)
