Understanding priority levels of ISR and FreeRTOS APIs
When FreeRTOS is manipulation its internal structures, like a ready list, it needs to make sure that no one else is going to also try to manipulate the structure. It does this by disabling the interrupts at and below configMAX_SYSCALL_INTERRUPT_PRIORITY. If an interrupt has a higher priority (lower value) than this and does call a FreeRTOS function (and the assert is present to catch it), and that function manipulates the same structure, that can result in a corrupted data structure, things like a task being lost from the ready queue is a very real possibility.
