Platfrom: stm32cubeIDE
I am having issues with accessing macro’s with the compiler throwing an undefined reference ? I am able to access functions such as xTaskCreate which is in the same file as xTaskNotifyStateClear.
Some of the other macros i have tried
xQueuePeekFromISR, xTaskAbortDelay, xPortGetFreeHeapSize
#define configSUPPORT_DYNAMIC_ALLOCATION 1
#define INCLUDE_xTaskGetCurrentTaskHandle 1
#define configMAX_SYSCALL_INTERRUPT_PRIORITY 6
#define configENABLE_BACKWARD_COMPATIBILITY 1
#define configUSE_PORT_OPTIMISED_TASK_SELECTION 1
#define configMAX_PRIORITIES ( 7 )
#define configTICK_RATE_HZ ( 1000 ) /* In this non-real time simulated environment the tick frequency has to be at least a multiple of the Win32 tick frequency, and therefore very slow. */
#define configMINIMAL_STACK_SIZE ( ( unsigned short ) 60 ) /* In this simulated case, the stack only has to hold one small structure as the real stack is part of the Win32 thread. */
#define configTOTAL_HEAP_SIZE ( ( size_t ) ( 2048U * 1024U ) )
#define configMAX_TASK_NAME_LEN ( 15 )
#ifndef configUSE_MUTEXES
#define configUSE_MUTEXES 1
#ifndef configUSE_RECURSIVE_MUTEXES
#define configUSE_RECURSIVE_MUTEXES 1
#define configQUEUE_REGISTRY_SIZE 0
#define configUSE_APPLICATION_TASK_TAG 1
#define configUSE_COUNTING_SEMAPHORES 1
#define configUSE_ALTERNATIVE_API 0
#define configNUM_THREAD_LOCAL_STORAGE_POINTERS 3 /* FreeRTOS+FAT requires 2 pointers if a CWD is supported. */
#define configRECORD_STACK_HIGH_ADDRESS 1
/* Hook function related definitions. */
#ifndef configUSE_TICK_HOOK
#define configUSE_TICK_HOOK 0
#define configUSE_IDLE_HOOK 1
#define configUSE_MALLOC_FAILED_HOOK 1
#define configCHECK_FOR_STACK_OVERFLOW 0 /* Not applicable to the Win32 port. */
/* Software timer related definitions. */
#define configUSE_TIMERS 1
#define configTIMER_TASK_PRIORITY ( configMAX_PRIORITIES - 1 )
#define configTIMER_QUEUE_LENGTH 5
#define configTIMER_TASK_STACK_DEPTH ( configMINIMAL_STACK_SIZE * 2 )
/* Event group related definitions. */
#define configUSE_EVENT_GROUPS 1
/* Co-routine definitions. */
#define configMAX_CO_ROUTINE_PRIORITIES ( 2 )
/* Memory allocation strategy. */
#ifndef configSUPPORT_DYNAMIC_ALLOCATION
#ifndef configSUPPORT_STATIC_ALLOCATION
#define configSUPPORT_STATIC_ALLOCATION 1
* to exclude the API function. */
#define INCLUDE_vTaskPrioritySet 1
#define INCLUDE_uxTaskPriorityGet 1
#define INCLUDE_vTaskDelete 1
#define INCLUDE_vTaskCleanUpResources 0
#ifndef INCLUDE_vTaskSuspend
#define INCLUDE_vTaskDelayUntil 1
#define INCLUDE_vTaskDelay 1
#define INCLUDE_uxTaskGetStackHighWaterMark 1
#ifndef INCLUDE_xTaskGetSchedulerState
#define INCLUDE_xTaskGetSchedulerState 1
#define INCLUDE_xTimerGetTimerTaskHandle 0
#define INCLUDE_xTaskGetIdleTaskHandle 0
#define INCLUDE_xQueueGetMutexHolder 1
#define INCLUDE_eTaskGetState 1
#define INCLUDE_xEventGroupSetBitsFromISR 1
#define INCLUDE_xTimerPendFunctionCall 1
#define INCLUDE_xTaskAbortDelay 1
