TMS470 port
nobody wrote on Monday, May 08, 2006:
Hi all,
I started to port freeRTOS to an ARM7-based TMS470R1B1M but now I’am facing some problems.
At the beginning I thought that it is no big deal as there are already some ARM7 ports available.
So I took the ARM7_AT91SAM7S port as example.
At the beginning I modified the timer initialization and the timer ISR and
both worked.
I did not modify the macros portRESTORE_CONTEXT
and portSAVE_CONTEXT as the assembler instructions should be the same.
But unfortunately, it does not work. After the following commands in
RESTORE_CONTEXT, the PC register points to somewhere.
    LDMFD    LR, {R0-R14}^
    NOP
    LDR    LR, [LR, #+60]
    SUBS    PC, LR, #4
Is there anybody who is working on a TMS470 port too or can someone point me to some hints?
I use gnu-arm-gcc 4.0.2, arm mode only and I started without using preemption.
TIA
Torsten
Well, after some modifications the context switch works.
I’ll let you know, when I’m ready with the complete port.
Torsten
rtel wrote on Monday, May 08, 2006:
I have a tms470 port that was sent to me recently, I’m not sure if it is complete yet and don’t have the means (yet) to test it.  I would be grateful for your port also when it is complete so it can become a supported processor :wink:
I’m surprised you had to change the macro definitions.  Did you start with a GCC port as your base, or the IAR SAM7 port?
The GCC ports can use inline assembler __attribute__((naked)) to keep all the code in the C files, whereas the IAR ports use a slightly different technique.
Also, did you call the first portRESTORE_CONTEXT from supervisor mode?  This is essentail, and the easiest way to do it is by switching the supervisor mode prior to calling main().
nobody wrote on Wednesday, May 10, 2006:
I’m also surprised. So maybe something different is wrong to with my port.
So could you send me the TMS470 port you got recently? It would be a great help for me.
Regards
Torsten
rtel wrote on Wednesday, May 10, 2006:
I can send it when I get back from my business trip.
What was it you had to change?
nobody wrote on Tuesday, February 13, 2007:
Do you think about publishing the TMS470 port ?
I’am a newbee with FreeRTOS and TMS470… and i would like to use it on the Olimex TMS470-P256 prototype board.
nobody wrote on Monday, February 19, 2007:
Hello there
I’m trying to port FreeRTOS to TMS470.
I’ve 2 tasks
- an LCD driver waiting for an LCDMessage
- another task trying to send a message when it starts.
The second task starts to work and queues a message to the first one. But when calling taskEXIT_CRITICAL() inside xQueueSend() function my software goes I don’t known where ?
I suppose that there is something wrong with task switching and/or interrupts…
Can someone help me ?
wintuvogga wrote on Tuesday, October 23, 2018:
Hi Guys,
Were you able to port FreeRTOS to TMS470.?
I am stuck at context switching part. I am able to initialize tick interrupt timer and after I start a task it doenst come back to the tick interrupt again.
Can some one please provide me the port ? It would be a great help.
Regards,
Winston
rtel wrote on Tuesday, October 23, 2018:
There is a port here:
https://interactive.freertos.org/hc/en-us/community/posts/210028366-TMS470M
It is VERY old, but may provide the piece you are missing.
Are you starting the scheduler from Supervisor mode? That is a requirement.
wintuvogga wrote on Thursday, November 01, 2018:
Hi Richard,
Thanks for this port. But this is not helpful for me since this chip is ARM cortex M series and also its built on CCS compiler.
Mine is TMS470R1B1M - High temp chip. Which is ARM7TDMI and using IAR compiler.
However I have little progress in setting up timer and interrupts and and starting up the scheduler. But I have a problem.
Problem: After the scheduler starts the task runs but hangs after first iterations. (timer interrupt comes only twice). After that PC points to some random location.
Observation: When I did step through I can see where exactly its jumping out.
---- for the first interrupt when vPortPreemptiveTickEntry() is called… Context switch is happening.
after the portRESTORE_CONTEXT chip is in System mode.
---- for the second interrupt when vPortPreemptiveTickEntry() is called in portRESTORE_CONTEXT function below two lines
*LDR		LR, [LR, #+60]
SUBS	PC, LR, #4*
The "LDR LR, [LR, #+60]" puts 0xE59F02F4 address on the LR register.
and "SUBS PC, LR, #4" puts the chip to unknown state. And debugger starts running, When I stop the debugger PC points to some where around 0xEC9C9988C which is actually no where. The chip is still in System mode.
Any ideas would be so helpful .
Regards,
Winston
Little more info.
This port is modified from LPC2000 series port of IAR.
in the startup.asm I have put the chip into supervisor mode before jumping into main.
And my tick interrupt is jumped to IRQ_Handler which is in C language which is in main.c
        ldr   pc,[pc,#+24]              ;; Reset
        ldr   pc,[pc,#+24]              ;; Undefined instructions
        b vPortYieldProcessor           ;; Software interrupt (SWI/SVC)
        ldr   pc,[pc,#+24]              ;; Prefetch abort
        ldr   pc,[pc,#+24]              ;; Data abort
        ldr   pc,[pc,#+24]              ;; Reserved
        b IRQ_Handler                   ;; IRQ
        ldr   pc,[pc,#+24]              ;; FIQ
IRQ_Handler in main.c
__irq __arm void IRQ_Handler(void)
  unsigned int a = RTICNTR >> 11;
  switch((0xff & IRQIVEC)-1)
  case CIM_COMP1  : vPortPreemptiveTickEntry();
  break;
rtel wrote on Thursday, November 01, 2018:
It sounds like the stack is getting corrupted, probably because you are
using the compiler’s interrupt entry code to enter the interrupt and the
RTOS’s interrupt exit code to exit the interrupt. I’m pretty sure you
have to have the interrupt entry code in assembler so the context is
saved as the scheduler expects and the stack frame is also as the
scheduler expects. See
https://sourceforge.net/p/freertos/code/HEAD/tree/trunk/FreeRTOS/Source/portable/IAR/LPC2000/portasm.s79
for the handler (as you probably have, and
https://sourceforge.net/p/freertos/code/HEAD/tree/trunk/FreeRTOS/Source/portable/IAR/LPC2000/ISR_Support.h
for interrupt entry and exit code (for the LPC2000) that must execute as
the first thing (before any C code that manipulates the stack as you
have it).
Hi Richard,
Thank you. Yes you were right. I removed the timer ISR callback from C and put the vPortPreemptiveTickEntry directly from startup.asm vector address. Now I can run the tasks as expected.
       SECTION .intvec:CODE:NOROOT(2)
    PUBLIC  __vector
    PUBLIC  __iar_program_start
    EXTERN UndefinedInstruction
    EXTERN vPortYieldProcessor
    EXTERN vPortPreemptiveTickEntry
    ARM
__vector:
b vPortPreemptiveTickEntry ;; IRQ
 Once I clean up the code I can share this port so that you could add it in the supported processors.
  But this chip is rare. It's Texas instruments SM470R1B1M High Temperature ARM7TDMI™ Flash Microcontroller. Used only in Oil and Gas / Space / millitary applications.  http://www.ti.com/product/sm470r1b1m-ht/description
  Regards,
    Winston
